So I have a Hifonics HFi2000d and I realized that my amp has no fuses, so basically I'm wondering what's the deal basically. I've got a fuse on the power wire from my battery to my cap(I know, I know, I just need to get the funds for the big three) but I don't know what to do. Should I leave it be, or should I add another fuse from the cap to the amp? I hope all this makes sense.
its prolly internally fused.
2002 ford focus hatch
pioneer DEH-P8400bh
infinity kappa 6.5 components front and rear
XS Power D1200
Shuriken BT-100
audioque 120.4
2 15 inch audioque HDC3 D2
2 audioque 2200d
big 3
mechman 220a alt with external regulator
479-418-3056
Id get a fuse going between the cap and amp if it was my setup. And if you upgrade that cap to a battery down the line you want to put a fuse just before the cap so both sides of that main power wire from front to back are fused. Always fuse before the amp to be safe. Even though if you do draw too much power you can pop the fuse under the hood however that cap will still have some stored power although it wont be much it is still something and can spark a fire if the amp itself shorted out. Be safe and put a fuse just before the amp and know your car is safe. Also do NOT exceed the power capability of the wire for the fuse size.
2004 GMC Envoy1 XS power S3400 batt under the hood and 4 XS Power D3100's battery installed in the rear by the amps0 gauge power wire from front to backAlpine iva-w205 touchscreen dvd/cd/mp3/ipod/am/fm/gps headunitSundown Audio SAX-200.4 amp for my mids and highs8 gauge speaker wire from amp to woofer270 amp Mechman AltRockford Fosgate T1652-s component speakersRockford Fosgate 3Sixty.2 sound processorRca's from Rockford Fosgate and Monster Cable14 gauge speaker wire for the mids and highs1 18" Ascendant Audio SMD Dual 1 ohm with custom Black & Blue carbon fiber and hand signed dustcapBox: 5.66 cubic feet net volume box tuned to 30.13Hz with 1.5" wide wooden dowels and 1.5" thick baffle1 DC Audio 5.0k amp wired to .5 ohms nominal with an imp rise of 1.35 ohms for the single AA SMD 18"Future Vision 8000k 50w bi-xenon projector HID's with 4300k 35w fog lightsLink to my build: Buildupdates/progress
Is that necessarily a good or bad thing?
depends. i no my AQ2200d is internal. sucks if u ever blow it cuz i think you would have to send it in to have it fixed but if you blow the fuse on the amp something prolly isnt right in the first place
pioneer DEH-P8400bh
XS Power D1200
Shuriken BT-100
audioque 120.4
2 audioque 2200d
big 3
479-418-3056
My wiring kit I used DB Link "1600 watt" has an 80 amp fuse I believe, how do they get the 1600 watts limit with the 80 amp fuse? Like how do they come up with that number?
Usually for every 1000 watts your amp puts out you will need 100 amps of power for it. What gauge is that wire? It sounds like it may be like 4ga or something. Also some manufacturers go way below the current capability of their wire size due to the wire not being of high quality and not being able to handle the true current that said wire gauge is supposed to carry.
wow to some of the above posts........
Anywhoo
If have have/look in the manual for that amp, it'll most likely tell you that you need an external fuse right before the amp and will tell you how large of a fuse you need.
EDIT: Sonic says a 200A fuse, here's the manual, go to about page 6 http://www.maxxsonic...er%20Manual.pdf
Edited by Lbox88
You need to get better power wire to start off with. some dblink 4gauge CCA wont cut it. 80 amp fuse at 14.4 volts gets you a maximum of 1150-1160 watts before it blows. You are starving your amp....
Go on Knukoncepts website. Get some Ogauge. Kolossus flex if OFC its better but the KCA 0gauge can still supply more than enough for your 2000watts. You need to get 2 fuse holders...2 200amp fuses and ditch the capcitor. You should probably think about getting a second battery as I'm pretty sure you will still have voltage drop with the big3 and stock alt/battery.
MY BUILD *****http://tinyurl.com/gmcbuild*****
Vehicles
2005 GMC Canyon
CB1000r - Currently where any future funds are going. (exhasut,bazzaz, ohlins shock, screen, etc.)
crf250r - Used to be race bike..now I just trail ride..practice at the track on it.
CH80 - Daily beater (when nice weather)best 150$ ever spent. 100+mpg
Sold to:
Skullz - pstone11 - Leo1103 - Volvo 63' - pavelpardo - imnew59585
Shower farts still piss me off.
I think theyre pretty neat. When the water runs down your crack as you let one out... its like shitting in a crockpot.
