RCP Audio Posted June 24, 2012 Report Share Posted June 24, 2012 I'm looking at upgrading my subs to something that can take more power, But the question is is will i be better off running my current amp (soundmangus dk1800) at 1 ohm (1800w rated). or should I get a second amp, the same amp, and run both at 2 ohms (1000w rated each) the subs will be able to take the power as ill be buying them depending on what amp(s) i go with. Will the voltage drop be worse running at 1ohm over having two amps wired higher? I know a single amp is easier and what not but id love to have two amps, gives me more options IMO PSN: Rcp_soundz Good rule of thump is go by what fuse size is being used in these amps. The higher the more amperage it pulls, this is what I look at. I'll stick a 300 amp fuse in a potato and sell it to you for $2k. 1991 Mazda 323VERY small build thread here: http://www.stevemead...23-small-build/ Link to comment Share on other sites More sharing options...
Watch the bass Posted June 24, 2012 Report Share Posted June 24, 2012 200 Watt´s more or less is unintresting in this range. "in the abundance of water, the fool is thirsty" Bob Marley Link to comment Share on other sites More sharing options...
95legwagon Posted June 24, 2012 Report Share Posted June 24, 2012 MOAR POWWWA i think there real i was looking through that guys stuff he sells and it looks like he finds stuff at auctions and just sells it Yea, it looks like someone got the mids about a month ago....shit. If I had a whole Hertz front stage my ears would jizz all over my cheeks. / LOL My Low Budget Build: Green 1995 Subaru Legacy wagon 147k- $1K headunit- pioneer premier deh-p650-$25 4 Lead acid batts. 1 up front and 3 in back- vented outside.- $50 4 vvme L11 10"s <- $30 shipped a piece 6 cu. ft box (after displacment) tuned to 32ish hz with 10 inch sonotube. -about $50 all together maybe a lil more 2 aspm 1300 strapped Selenium 6"s in the front doors on headunit power- for now -$20 quantum tweets in door-for now -$10 boston acoustic 5 1/4 in rear doors- for now-Free big 3 1/0 and 4awg throughout. roof sound deadened (not peel n seal ftw)-free on 80 amp alt (bench tested to put out 100 amps faithfully) <--?-$10 for test about $430 for everything<----Not bad at all still gotta add 3 way crossover, amp for front and rear door speakers and maybe eq Link to comment Share on other sites More sharing options...
RCP Audio Posted June 25, 2012 Author Report Share Posted June 25, 2012 200 Watt´s more or less is unintresting in this range. I know thats true, but what will be better for my voltage is what im trying to figure out PSN: Rcp_soundz Good rule of thump is go by what fuse size is being used in these amps. The higher the more amperage it pulls, this is what I look at. I'll stick a 300 amp fuse in a potato and sell it to you for $2k. 1991 Mazda 323VERY small build thread here: http://www.stevemead...23-small-build/ Link to comment Share on other sites More sharing options...
8ight Posted June 25, 2012 Report Share Posted June 25, 2012 200 Watt´s more or less is unintresting in this range. I know thats true, but what will be better for my voltage is what im trying to figure out One amp, of course. You're halving the amount of static current draw from things like the onboard EQ alone, then halving the efficiency loss you experience when making the power. I'm gonna hate Link to comment Share on other sites More sharing options...
BobbyG2 Posted June 25, 2012 Report Share Posted June 25, 2012 Two amps at 2 ohms each would be more efficient at the same power than 1 amp at 1 ohm. But I'd rather use that money to upgrade my electrical instead. *New vehicle and system coming soon.* Link to comment Share on other sites More sharing options...
MrSkippyJ Posted June 25, 2012 Report Share Posted June 25, 2012 If you can't support 1.8k at 1 ohm, I doubt the efficiency gain of 2 amps @2 ohms will help. You are getting more power and saving maybe 5% efficiency depending on what amps. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69 Link to comment Share on other sites More sharing options...
RCP Audio Posted June 25, 2012 Author Report Share Posted June 25, 2012 Two amps at 2 ohms each would be more efficient at the same power than 1 amp at 1 ohm. But I'd rather use that money to upgrade my electrical instead. thanks a good idea hah. time for a new alt PSN: Rcp_soundz Good rule of thump is go by what fuse size is being used in these amps. The higher the more amperage it pulls, this is what I look at. I'll stick a 300 amp fuse in a potato and sell it to you for $2k. 1991 Mazda 323VERY small build thread here: http://www.stevemead...23-small-build/ Link to comment Share on other sites More sharing options...
