Best sub to run on Kicker DX300.2
I have a Kicker DX300.2 that I got for $100 from a local shop. Right now, I have a Type E 12" in a sealed 1" enclosure. I want a bit more power. Which sub would you recommend?
Alpine CDE-164BT/Rockford Fosgate P400X4
Kicker CS 6.5" Components (Front)
Kicker 6.5" Composites (Rear) (Running at -10DB for soundstage)
RF P400X1 Monoblock
2x Rockford Punch P1 12" 4 OHM SVC running @ 2 OHM in sealed 1" MDF box.
Not sure what you mean by a 1" enclosure, but anyway in the 300W department, look into the sundown E series, Skar IVX's, SSA DCON's... dual 2 ohm or single 4 ohm is what you'll want.
I'll also add the option of Obsidian audio! And then if you decide to upgrade power later, you wont have to upgrade the sub.
*New vehicle and system coming soon.*
Without knowing budget, and size restriction, and if you can build box
You'll need to have a final load of 4 to get 300rms out of that
This will work very well (but in 4ohm final load)
http://www.sonicelectronix.com/item_21944_Kicker-DC122-10DC122.html?from=857-49
Or
http://www.sonicelectronix.com/item_21945_Kicker-DC104-10DC104.html?from=857-49
Or even
http://www.sonicelectronix.com/item_21900_Kicker-VCVR154-10VCVR154.html?from=857-49
Many people will dis me for recommending them but for the price and with a box I know worka very well with them, there a easy way to get into some bass,
I know a lot of people running theis sub/box setup and are very happy
If you have the space a SSA DCON 15" will increase your output a lot with the same power you have now..
On a tight budget changing the enclosure of your sub for a big ported you will also see better output without buying anything.
I have a wagon. I have the space for 2x 15" if I want, but power is a concern. 160 AMP alternator with the Big 3 done with 0 Gauge Bullz (Just fine for short runs, didn't feel like spending 3x the money on cables for 2-3 feet runs. The cable going from the fuse to the rear is a Stinger 0 gauge, since that is a longer run. I like the suggestion for a 15", as I do have the room. While my cables can handle the load, I am using a 300W rated Amp, so I will be limited to a single sub rated for 300-400 RMS. The Amp actually rates to 330 bridged @ 14.4V, which my car constantly outputs.
My current enclosure uses 1" thick MDF and is sealed. It sounds good, but I definitely need more power. The Type E is a pretty weak subwoofer. While it is 250 RMS, it doesn't have the response or deepest throw.
Edited by Sean Sinha
RF P400X1 Monoblock
Your not restricted to a single sub there are many subs that run well in 150rms so 2 on 300 is perfict
The 2 kicker comp 12 in a kicker box work well and go loud for a 300 rms setup
Your only restriction is 4 ohm final load
Edited by john253a
RF P400X1 Monoblock
skar sk2500.1
alpine HU
vxi65 components on BA gt-275
2 x-15 sundowns
  • Who's Online   1 Member, 0 Anonymous, 573 Guests (See full list)
