ground loop
whats the best way to eliminate a ground loop? i did the wire around RCAs on deck ( pioneer) but i still have a whine gets louder as rpms go up.. sometimes it comes threw the subs also
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
Yes Im going to add a couple more, have 5 neg runs front to back And 4 off batts to frame
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
when you wrapped that wire around the rca did you ground it to you cd player? my pioneer was having the same proplem and i wrapped some 16gauge around the rca's and then grounded it to the cd player and it fixed it completely.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
Did that before i put it in, bought it brand new and did it haha
I tried wrapping wire around RCAs on amps and it made it worse
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
would wrapping wire around RCA jacks on amps, then grounding to rear batterys be a good idea?
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
im curious about this as well
tried this, didnt work
when i wrap a wire around an rca, and just leave it attached to nothing, plug the rca, its gone, but bass doesnt play....
Had the same problem with my pioneer, rip it out, and electrical tape the shit out of you're ground wire, problem solved
1997 Trans Am WS6
Pioneer DEH-P5200HD
2 DC Level 4 M2 12s
4 cubes tuned to about 34hz
DC 3.5k
1/0 Welding Supply Ultra Flex
Stock 140A alt
Stinger Fuses & Fuse Holders
XS Power D5100
XS Power XP3000
ive got really bad alt whine too, just when i push the rcas in, it goes away, and never touch it its fine, but once they touch the back of the slot for the headunit it comes back, ima ground loop it see if it works for my kenwood.
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
  • Who's Online   0 Members, 0 Anonymous, 1025 Guests (See full list)
