Custom plexi back to show of them guts!
* Eclipse CD3200 with PAC SWI-CAN2 and SW-ECL2 Steering Wheel Controls Interface
* Pioneer D-Series Mids and Highs ( Fronts: TS-D1702C; Rears; TS-D1702R and Dash; TS-D1002R )
* Rockford Fosgate PBR300X4 ( Mids and Highs Amp )
* DC 3.5k with Dual Inputs; Custom Plexiglass Backing ( Sub Amp )
* Rockford Fosgate Balanced Line Driver
* One FULLY LOADED ~ 10" DC m2 XL
* Custom Built Carpeted Ported Box Tuned to 32hz. Single Chamber With Volume of 1.44618³ ft ; 1.13216³ ft After Displacement
* Custom Built Carpeted Trunk Wall with Added Fans for Amplifier Cooling
* MechMan 240a High Output Alternator
* KnuKonceptz Krystal Kable RCA Cables
* Upgraded Electrical With 1/0 KnuKonceptz Kolossus Fleks Kable and 1/0 Sky High Car Audio Cable
* Five Exide Orbital ORB34M Marine 12 Volt Batteries
* PowerMaster XS D3100 12 Volt Battery
My 2008 Chrysler 300 Limited - SuperCharged 3.5L V6 - UBL
My Old 2005 Ford Taurus - CarDomain - Vehicle Was Sold
  • 3 months later...
sexy, cant wait till i can save up enough to get my 2 2.0k's and my xl 12s!
down rpping vanderbilt. 30 miles from victoria. i own the 3rd loudest setup here out of 3. but i did put together all 3 setups
strapping 2 amps together ? like bolting them next together? using bungy cables to hold them down? or wiring separate amps to each sub
  • 4 weeks later...
The DC Audio amp from above.
Above is a picture from Audiopipe APK I believe.
That one is a Crescendo BC2K I believe.
I grabbed these pics from a bench test thread on CACO for the APSM-1500.
I am NOT saying these amps are the same by any means but they look very similar. I am just looking for some input on how often multiple amps use the same boards. Do they use the same components? Is there a place to go that has information like this?
2012 North American Street Stock Runner-up - 150.9 on 1800 clamped watts (Teammate)
2013 dB Drag Street Trunk World Champion - 153.9 on 3200 clamped Watts (Teammate)
2013 MECA Trunk 1 World Champion - 152.8 Headrest (Teammate)
2013 MECA Park & Pound 2 World Champion - 130.6 (Teammate)
Checkout our build and videos !! : ) 150+ Trunk Build Log itsgordy1 youtube channel (click for Hairtricks)
Smith's Custom Seats
Martinsburg, PA
(Second Skin Dealer)
ill say its because of the name on the heat sink
2000 Suburban 6 runs of 2/0
12 JBL Pro audo mids ,6 timpano audio tweets and 1 Prv compression horn per door
475ah of yin long LTOs
Triple 370 Amp Autotech Alts
mids amps 2  Crescendo Skyway 3ks
compreesion horn amp crossfire 800.4
Tweet amp Crossfire 2000.4
sub amp: 4 Crossfire XT 8ks
Subs: 8 18 in Crossfires in a 4th order
Best Scores at events…
163.5@38hz DBdrag  sealed on the dash… 164.3 outlaw…162.9 Meca headrest
Just because the boards look the same doesnt mean the parts used are. There is a reason for the price difference.
So the difference is the components that get put on the boards? So if I bought each of these amps and really looked close, one would use 10% tolerance resistors and one would use 5% ones? I guess I just like an overkill of information when looking at things and transparency of facts.
It is just confusing for consumers. Its like if 5 companies bought the same vehicle body and just put their own different spark plugs, headlights, etc. in it and then put their badge on the grill. They look the same and supposedly one performs better than the other, but without specifics about what is different or first hand experience, you have to be careful about believing what you hear.
I am in NO way saying a DC 2K is the same as a Audiopipe amps......I am just asking questions on a larger level when it comes to differentiating products in an industry that is very biased when it comes to reviews and contradictory as far as credible information goes. It just happened I saw these pictures after reading the post on CACO with those other pictures and it peaked my interest.
Martinsburg, PA
