DC Sound Lab
Now Im pretty sure no one at all does this but.... Will or could DC ever offers an option to have any color board you want? Or is that just how thew build houses do it? (Each company gets a different color) heck Id pay extra if I could choose the color of the board.
* Eclipse CD3200 with PAC SWI-CAN2 and SW-ECL2 Steering Wheel Controls Interface
* Pioneer D-Series Mids and Highs ( Fronts: TS-D1702C; Rears; TS-D1702R and Dash; TS-D1002R )
* Rockford Fosgate PBR300X4 ( Mids and Highs Amp )
* DC 3.5k with Dual Inputs; Custom Plexiglass Backing ( Sub Amp )
* Rockford Fosgate Balanced Line Driver
* One FULLY LOADED ~ 10" DC m2 XL
* Custom Built Carpeted Ported Box Tuned to 32hz. Single Chamber With Volume of 1.44618³ ft ; 1.13216³ ft After Displacement
* Custom Built Carpeted Trunk Wall with Added Fans for Amplifier Cooling
* MechMan 240a High Output Alternator
* KnuKonceptz Krystal Kable RCA Cables
* Upgraded Electrical With 1/0 KnuKonceptz Kolossus Fleks Kable and 1/0 Sky High Car Audio Cable
* Five Exide Orbital ORB34M Marine 12 Volt Batteries
* PowerMaster XS D3100 12 Volt Battery
My 2008 Chrysler 300 Limited - SuperCharged 3.5L V6 - UBL
My Old 2005 Ford Taurus - CarDomain - Vehicle Was Sold
I do t even know if it's possible but the answer is no. The amps are mass produced and I doubt you could custom order just one.
iirc, i think i saw someone vinyl wrap their 12k white
'08 Chevy Cobalt coupe 2.2 base model trunk build:
2 9512iSC flatwound alum 1.5 coils
-extra 9500 spider pack
-8" platinum carbon dustcaps
1 DD Z1 (.375ohm nominally daily)
3g31 AGM
320a Ohio Gen alt
1 DD S4 4 channel
4 VO-M8v1's (holes cut for 3rd pair)
2 CS 6.5's
2 VO-B1's
Sony XAV-601BT
all Knu Krystal RCA's
Cadence 7band EQ
______________________
148.3db @ 32hz (burp)
148.4 @ 37 & 38hz (burp)
146.xdb 90sec average (center windshield)
even with the cover off, you don't see much of it. Not enough to justify the extra cost
What you just said made no sense at all.
Yeah but I'm talking about the circuit board.
Yeah I figured as much, being that they're mass produced.
oh my bad.
i was skimming and didnt see due to extreme exhaustion...
3g31 AGM
320a Ohio Gen alt
1 DD S4 4 channel
2 CS 6.5's
2 VO-B1's
Sony XAV-601BT
Cadence 7band EQ
Its possible. Most consumer electronics use either red or green boards but I've seen blue, yellow and of course brown boards.
The CM (contract manufacturer / build house / board house) would have to order colored circuit boards from the company that makes them.
As Cody mentioned above, they're mass produced so the more changes you have, the higher the cost.
If the circuit boards are rated at a higher temperature then most consumer electronics then that also may affect the color options...
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
iPadMini2
Dash mounted O-scope
Highs Amp - PPI Art A404
DC Audio DC9.0K
2- DC Audio XL12m2
JUNE 2014 SOTM WINNER
SOTM BUILD:
I never thought of a tempature tolerance.. that does make sense.
The color of the PCB has no impact on it's performance since pigmentation can be added during the manufacturing process rather easily. Many motherboard manufacturers do this to create a brand identity or accent high-end equipment. Due to the massive volume PCBs are ordered in to keep costs down it would not be effective to offer color choices. It would be far simpler to switch the color for every board, but likely not since that may entail moving to another supplier and losing a juicy volume discount built up over time.
EDIT: Temperature tolerance is determined by the thickness of the board overall and how much copper is inside of it. That is why many motherboard manufacturers use terms like "XX layer PCB", "XXoz copper PCB", or what have you. To a PC performance enthusiast that means higher component stability under the harsh conditions of overclocking etc.
Edited by 8ight
I'm gonna hate
  • Who's Online   0 Members, 0 Anonymous, 905 Guests (See full list)
