Absolutely
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Yes sir had it happen before
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
Have a DMM?
Measure shield to center conductor on each side.
Should be a very high resistance. I'd you're below the mega-ohm range they're iffy.
Then measure center conductor to center on each side. Should be under an ohm.
The only scenario would be if the rca's were shorted between the center and shield.
That would be impressive if an amp caused an rca cable to short...
If that's the case, I have access to an X-ray machine.
I'd pay to X-ray that cable.......out of curiosity.
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
iPadMini2
Dash mounted O-scope
Highs Amp - PPI Art A404
DC Audio DC9.0K
2- DC Audio XL12m2
JUNE 2014 SOTM WINNER
SOTM BUILD:
An open cable is like no cable = no problem.
Any decent amp has protection from shorts on the input and output so no RCA cables should be able cause amp failures.
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
iPadMini2
DC Audio DC9.0K
2- DC Audio XL12m2
SOTM BUILD:
  • Who's Online   0 Members, 0 Anonymous, 1973 Guests (See full list)
