Dirty ass seats!!
all that dust cleaned up
Now the Interior LEDs will go on/off with the underbody led kit. Paul likes the color green so I tapped into the interior led kit only and added a switch so he can turn on only the interior leds at any time, but they will only be green.
2nd switch will be for any new possibilitys of adding more lighting, so power/ground is pre did.
Here is something that bugged me for a while. contaplated how to fix the problem of the hole in the carpet, it needs new carpet for a proper fix, but the problem still exhists that that carpet does not go flat on the floor, there is a a/c & heat vent right there, which leaves the carpet off the floor. This is where paul pushes himself up and out of the car with his right heal. It wore thru the carpet. Genius design by Dodge!
Made a riser with mdf.
blurry picture, but i wrapped it with a sheet of Damplifier Pro 80mil from Second Skin to help resist moisture and water.
and its in place now
rear beauty panels under the 4500s
In this last picture you can see a mdf box on my table saw I made up quick, this is to mount the oem fusebox that was in the wheel well before being removed when it got filled with d3100s.
I ended up rounding all corners, and also wrapped in vinyl too.
Here is the said fuse box that is just laying around
and with the box i made and wrapped and one of the false floor panels in place
both bottom panels in place with the fuse box
and with some accent lighting
brought out the two 4channel amps, to try and figure out where to put this XS Power battery charger.
amps are straight in this pic with charger in middle
amps slanted and charger in the middle
or charger off to the driver side to of the car.
I'd say slanted, and manage to find a way to hide the Intellicharger's wires.
Awesome work feg. Keep er up!
*06 330i - Sundern x12 - saz-3500*
*91 Foxbody V1 S-Trim Notch*
hidding wires is easy. bring them to the front of the box and down around the side ;)
Back of the box is already taken up by the saz4500s, so the majority of the black heat shrunk wires wont be seen much either.
anyways, pictures before I go shower and crash for a few hours.
since Im still sorta undecided on the battery charger I moved on from it to sleep on it, and started the voltage meter housing in the never used ashtray.
Probably will finish up some touch ups tomorrow, prime and spray it.
Its currently 40degrees outside in my area so going super slow taking lots of breaks :(
Im not perfect at wrapping, but getting better and better, my adhesive I think is holding me back, so I talked with Ray West and he gave me some info, also need to buy a new heatgun something fierce, just seems like its getting no where near as hot as it did a few weeks ago.
Its about 30-32 degrees outside, so I mainly messed with some smaller stuff inside the garage even tho I could do a lot more tonight.
I turned the garage heat on just a tad to about 45degrees and worked for a few hours before heading inside.
Just messed with the ashtray a little more, and hopefully the paint will dry nice for me (crosses fingers).
Also check out my screwdriver bits in my case :D
You see what I did there? LOL
Very nice attention to details!
It takes a while, but then you get something different from normal.
22 cal?
Woofer: 12" Phase Linear Aliante Limited
Mids & highs: DLS Ultimate 5 1/4"
Amp: Audison VRX 6.420
HU: Sony CDX-C90R
