OK so I decided I would try to design a 4th Order Box for 2 SA-12's and here is what I came up with,
Sealed Portion Specs
Ported Portion Specs
The Box Built in Sketchup,
So I would like some critique on weather or not I designed this right and if I didn't design it right what I did right,
Thanks,
KCowboy620
!999.5 Volkswagen Jetta
1 Planet Audio BIg Bang 15
Powerbass 1500,1
I think the box ratio is good. I have seen several 4 th order boxes loaded with the subs firing towards the port and they worked well. I am curious what you are going for. Spl? Or a daily driver? If a daily driver I would try and design it with a tunable port. I will give you muck better chance of getting the port how you want it without rebuilding your box.
get the sealed up to 2-2.2net and ported down to 3-3.5net and higher tune
My only concern other then the low tune would be the orientation of the subs, im wondering if facing them at the port like that will cause port unloading.
I thought I saw somewhere that as long as you couldn't see the subs through the port then it would be okay, but i could try to figure something else out
Yes it would be for a daily driver and what should I tune it to for best performance in a daily
Powerbass 1500,1
2.2 sealed
4.2 ported
Tune to 41-42
15sqin per
Good start
2.2 sealed
4.2 ported
Tune to 41-42
15sqin per
Good start
Alright thanks I'll try to figure something out for the space I have to work with
Here is what I got this time it's as close as i could get to those specs without using really weird fractions
Sealed side
Ported side.
Powerbass 1500,1
How does one determine how big to make the sealed area and how large and where to tune the ported area? Are you guys running formulas, guessing blindly, or are you using software? I have BBP6 and winISD on my other laptop, but its slow, so i usually just stick to my mac.
  • Who's Online   0 Members, 0 Anonymous, 789 Guests (See full list)
