Metals to use for a Bus Bar???
:lol2:
u mean dude saying gold is the best is..... the weakest link
goodbye :hay:
SCSB
Santa Cruz Speaker Box
Build logs:
Daily Driver Lemon Marquis
2 american bass 750.1s
350.4 on 14 focal 6.5s
sq 945 on 4 hertz tweeters
http://www.stevemead...__fromsearch__1
The Mustang 'dubbed' Shirley the project from bullet holes to badass
http://www.stevemead...cond-skin-time/
  • 5 months later...
I am looking at making my own buss bars, however due to the orientation of my batteries I have to use bends. I am looking at .125 thickness/.5 width copper flat bar, I could also use the same in brass as they are relatively close in price. My question is which metal will be better and easier to bend, these will be simple 90 degree bends and I thought of using a butane torch to heat up the bars for the bending if needed depending on the bars flexibility at this thickness.
Hopefully someone will chime in here.
Thanks
Retired from SPL again....
2016 IASCA Truck/Trunk 2 Champion 151.8db
2016 IASCA Truck/Trunk 2 World Record Holder
Copper over brass all day plus it's alot softer an easier to bend
TEAM DC AUDIO
VEHICLE:98 chevy tahoe 2wd 3-4 drop
HEADUNIT:alpine 9886
PREAMP:arcaudio
FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door
KICKPANELS:jl audio 5 1/4
REAR DOORS: dd components 6 1/2s
HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors
SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV
SUB AMP: 2-dc7.5s
ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
Thanks
Hey man, don't post here often but i know some things about conductors that'll help you. I'm not sure what your running but you would probably want bigger bus bars. Those dimensions would give you a size that is equal to a wire that is slightly smaller than a 2 AWG wire. I would double the area of your bar, as this would make it have similar conductivity to something like 2/0 wire.
If you have any questions about this stuff, just ask i'll be glad to help :)
I ended up going with solid copper. I found a company called Strom Copper that makes them up already for grounding and they are CHEAP for complete sets!!!!
149.4 Db @ 30Hz Outlaw With One 15" Fi Team Sub, Trunk Build. !!!!!Hair Tricks!!!!!
Check Out The Build Log http://www.stevemead...0-4-and-t400-4/
Watch The Videos http://www.youtube.com/user/jcplaya3
  • 7 months later...
Edit: late to the party lol. Buss bars look AWESOME
  • Who's Online   1 Member, 0 Anonymous, 1062 Guests (See full list)
