DC Sound Lab
Decaf all day long and box is 6 cubes with displacement tuned to 32hz
something just clicked what is your subsonic filter at cause you said you played a 20hz tone
skar sk2500.1
0 gauge power and ground kunukonceptz
alpine HU
vxi65 components on BA gt-275
new build log -> http://www.stevemeadedesigns.com/board/topic/150642-project-d-kon-deathcards-build-log/#entry2148821
2 x-15 sundowns
singer alt, odyssey bat, and maxwell ultra caps
Is it wired right? I've heard of coils out of phase doing this
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
Recone is from 2 months ago but its only been play a month or so id say its broke in pretty good. I dont play 20hz at all but bass boost is down all the way same with subsonic lowest i play is 30hz and its wired to .5 and i only have 1 sub
89 Ford Bronco 2
6 DC XL M2 12's
1 DC 9K
Dual Singer Alts
7 Xs D3100s & 1 D6500
All Audio Techinx OFC 1/0
Doing 55s at 26hz!!!
Missed that cj. I honestly think its a bit large for that much power it is still a four inch coil right? Throwing retarded amounts of power at a single woofer is never a good idea. If it was out of phase it would heat up but output should be reduced as well you'd think that would be noticeable in a single sub setup,
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Also he could be running into serious voltage drop and that could be causing issues as well. A 5k at .5 is a silly amount of draw
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Was the sub level on the deck at 15/15 when you dd-1'd it?
What's your voltage at full tilt?
under construction
I hate People with crappy primered cars rolling on hubcaps that are louder then me.
u hate c-fizzy?
the new box will be 5.25 cubes but im not building a box for a blown sub lol it aint out of phase
89 Ford Bronco 2
6 DC XL M2 12's
1 DC 9K
Dual Singer Alts
  • Who's Online   0 Members, 0 Anonymous, 16919 Guests (See full list)
