AI-SKYnet-HR69 Posted July 17, 2012 Report Posted July 17, 2012 i need some help with this box design! was wondering if it was best to put both subs in a big single chamber or 2 seperate chambers?? need it to be @ least 3.8cu ft or more after displacement of sub and 45degrees max dimensions in trunk! for now.. 40" length 18" height 23" width if someone can help me that would be great! Quote
bassface Posted July 17, 2012 Report Posted July 17, 2012 Joe x is usually pretty helpful on boxes, see if you can contact him. Quote
CleanSierra Posted July 17, 2012 Report Posted July 17, 2012 Quote Im not the one you want to try to troll. Just a fyi for you.
CleanSierra Posted July 17, 2012 Report Posted July 17, 2012 ^^^That was about 1 minute of time playing with Torres. I guessed on the sub displacement and bracing. 45's don't take up TOO much space. You didn't say what vehicle, what power, or anything like that, so I'm not sure about what you're looking to accomplish. I'm pretty sure the SoloX's like a LOT of airspace though. Quote Im not the one you want to try to troll. Just a fyi for you.
TeamHT Posted July 17, 2012 Report Posted July 17, 2012 I read it as he wanted the front baffle angled at 45 degrees. Quote Tell me...does this smell like chloroform to you?
john253a Posted July 17, 2012 Report Posted July 17, 2012 (edited) I think he talking about the alpine x 12 You'll want 1k each to them to get any sort if numbers, the don't require a masive port either What car What sub and port direction How much power What do u lission to What do you want a achieve with them Edited July 17, 2012 by john253a Quote
AI-SKYnet-HR69 Posted July 17, 2012 Author Report Posted July 17, 2012 the subs are going into a 06 malibu LT! i already have custom amp rack and battery rack thats why my space is a lil limited! going to be running 1700rms to both subs for now but going to be pushing 2400rms to both in a month or so! im looking for more sql than spl! tuned to 32-36hertz Quote
CleanSierra Posted July 17, 2012 Report Posted July 17, 2012 I read it as he wanted the front baffle angled at 45 degrees. I think he is meaning to INCLUDE 45s, since he mentioned it right around displacement of subs. I'm not OWNING any design by any means, just crunching some quick numbers for him. I'm not sure the airspace is even correct. I know port aread looks good, but I'm not sure what the response would look like with those things. I've always thought they were hungry for air. Quote Im not the one you want to try to troll. Just a fyi for you.
AI-SKYnet-HR69 Posted July 17, 2012 Author Report Posted July 17, 2012 I read it as he wanted the front baffle angled at 45 degrees. I think he is meaning to INCLUDE 45s, since he mentioned it right around displacement of subs. I'm not OWNING any design by any means, just crunching some quick numbers for him. I'm not sure the airspace is even correct. I know port aread looks good, but I'm not sure what the response would look like with those things. I've always thought they were hungry for air. I read it as he wanted the front baffle angled at 45 degrees. I think he is meaning to INCLUDE 45s, since he mentioned it right around displacement of subs. I'm not OWNING any design by any means, just crunching some quick numbers for him. I'm not sure the airspace is even correct. I know port aread looks good, but I'm not sure what the response would look like with those things. I've always thought they were hungry for air. yea im ment to say that i also want 45 degree angles in the box! also want to do a single chamber box.. i want to see if it will sounder louder than my friends type X's cause he has both subs in their own chamber tuned to 32 hertz with around the same amount of power that ill be pushing to these babies Quote
Joe X Posted July 17, 2012 Report Posted July 17, 2012 (edited) Here is an updated suggestion exactly as requested : Enclosure Specifications: Fb = 34.5 Hz Vb = 3.8 ft^3 External Height = 17 in External Width = 35 in External Depth = 19 in Port Width = 3 1/2 in Cut Sheet List: * All Dimensions in Inches. * Wood Thickness is 3/4 for all Parts. External Enclosure Parts: 2 x Front & Back (3 parts) = 35 x 17 Left & Right Sides = 16 3/4 x 15 1/2 Top & Bottom = 35 x 16 3/4 L Port Internal Assembly Parts: Front to Back = 13 1/4 x 15 1/2 Extension = 5 1/2 x 15 1/2 Assembly guide (generic dimensions): Edited July 17, 2012 by Joe X Quote
