how to wire 6 10s
ZachG
Ok so as far as 15s either two cvrs or two of http://store.soundsolutionsaudio.com/products/sundown-audio-e15-subwoofer-400w-e-series.html
Or maybe still could do 4 10s...wouldn't be as much cone but the motor force would be more & 4 10s is less common too
1998 Pontiac grand prix gtp supercharged2 12" Obsidain Audio V.1 on a 2011 zx1500.1 at 2 ohms. 20ft of Knuconceptz CCA 0 Guage. 2nd Battery is a Shurken BT-120. Box is 3.5cu tuned at 31.8hz sealed off from the trunk. 14sqft of Dynamat on the Rear deck top & bottom. Soon to be more for doors/roof. Gets low & loud
Did a 140.5 Sealed at Battle of the boom in June 2013 dropping to 12.7v (need a alt mines going bad)
oh man. 6 10s in a trunk?! goodluck! haha
Haha yea that's the problem here. I might have to go to my original idea of 4 Memphis pr 10s on a zx1000 but I'm Gunna play around with Torres and see
Kicker comps work well in infinite baffle setups in case you decided to attempt that.
Ok I'm not Gunna have the room to do 6 10s properly so I'm just Gunna do 2 obsidian audio 15s with 3.25cubes ea tuned to 32hz..
Now I need to figure out how to use Torres properly to make a box with my diameters of 15.5h-33w-32d
Going to get this with the two obsidian audio 15s
http://www.sonicelectronix.com/item_23548_Hifonics-Brutus-BRZ1200.1D.html
I had 6 tens in my trunk! All I can say it I'm not sure whether the rattle or the bass was louder......
OP that sounds fantastic, get to it.
2015 Subaru Outback. That is all, I refuse to touch it.
im not saying its impossible. that just takes planning and most likely will have to build in trunk. just a lot of factors. thats why i said goodluck. and plus why would you want to not be able to tell if the rattle or bass was louder? if possible you dont want any rattle in a perfect world. thats why we use deadner to remove panel flex and rattle as best we can.
anyway, OP, goodluck.
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
could make a blow-through style setup in the trunk to maximize available volume. Bolt a baffle behind the rear seat, mount subs at an agle like truck blowthroughs, then rhino-line the trunk and bolt the lid down... :P
Hammerdown... 1%
You can do subs front and a couple of 6" aeros (minimum) to the side on those dims.
Well I don't feel like ruining my car and with the max diamsions I listed I still have about 32x8 of trunk left if I do need to put something in it
Hey I like the idea with the aeros cause then I can defiantly build the box my self.
& since my car the rear seat arm rest when its down goes straight open to the trunk do you think I can put the aeros in the rear near that opening to my cabin and have the subs faceing back to the trunk lid??
Or would it be better to do the subs faceing front to that opening and aeros in the rear to reduce rattles but then not be as loud?
  • Who's Online   0 Members, 0 Anonymous, 1103 Guests (See full list)
