Portable hard drive instead of flash drive?
Just wondering if these decks that have usb ports can play music files off a portable hard drive, something like a WD Passport for example? Reason i'm asking is cause my deck (listed in my sig) has a usb input which I normally connect my iPod to. My 64 gb iPod Touch is full now and I was thinking about getting another one but then I started wondering about this idea. Right now I have a 320gb Toshiba USB 3.0 portable hard drive in my cart on Amazon, it's like $55....would this work?
I wouldn't really be losing out much by not using the iPod cause I can't see the album artwork or change song ratings when it's plugged in to my deck anyway. And also, the Toshiba doesn't need a power source, it gets powered up the by usb port.
What ya think?
Alpine CDA-117...Memphis 16-X03
CDT Audio SQA-4100...SEAS Prestige H1396...Crescendo MP-6
Soundstream Rubicon 1.2500d...Digital Designs 3512f
Why dont you buy one from walmart and if it dosnt work just return it.
Build Under Construction
Head Unit = Kenwood DDX514
Amps = Kicker 750.1, Going to install Sundown 1500D v3 and Sundown 125.4
Battery = XS D3400
Wires = Kicker RCA's, 0 Gauge street wire and Stinger
Mids and Highs = Stock
Sub= Kicker L7 12"
Alternator = 220 Mechman
Sound Deadner= Fatmat and Stinger Road Kill
My headunit has a usb thats in my sig and it doesnt work with a 320g
Battery = XS D3400
Sub= Kicker L7 12"
probobly would end up being slow if it did work, i highly doubt something that high of a capacity would work though.
I took my 320g external hard drive to a geek teck friend of mine and had him to partition 3 sections on the drive to FAT32 and leave the rest NFTS (I think that is what its called) 120 something gigs left ...
Works great on my Kenwood DNX9980HD unit ... but has not worked on any other head unit I tried ...
hope this helps some ...
im interested to know if mine works or not now. Im gonna check when i get home. i have a pioneer so no help to you, but ill let you know
PSN: Rcp_soundz
Good rule of thump is go by what fuse size is being used in these amps. The higher the more amperage it pulls, this is what I look at.
I'll stick a 300 amp fuse in a potato and sell it to you for $2k.
1991 Mazda 323VERY small build thread here: http://www.stevemead...23-small-build/
Now my headunit only sees those FAT32 partitions ... It does not see the other partition, no matter whats on it ...
So my guess is ... If its not set up in FAT32 format, its not going to work at all ...
It's very common for media devices to read only FAT32, my 160 gb ipod is in FAT32 as well, and being harddrive based, it actually load all my songs very quickly on my Kenwood DNX 7100.
2003 Kia Sorento
Team Subsonic Lows
Team Bassin' on a Budget
I have a Pioneer p4000dvd and a seagate freeagent 250gb. They worked flawlessly out of the box for about a year and a half, then the seagate started to die slowly.
one problem I read about was that portable hard drives with disc can get damaged if they take too much vibration (ie: YOUR BASS), so I think that's what happened. Either that, or my deck stopped powering it correctly.
It is true that the decks only recognize fat32, but there are more than a few programs online that you can download to make the hard drive fat32 format with the entire capactiy available. I don't remember the names, but I've used googled, found, lost, and re-found the programs a dozen times.
Either way, YES, they work....and mines was working 2 years ago, daily, with over 30 gbs of music on it. The head units are only restricted by how many folders they can load. Some have a folder structure limit or a file limit. The easiest way to find out is to take your portable hard drive to a car audio store that has the deck you want and simply connect it.
Learning Everyday.
Pioneer AVH-P4000DVD
Alpine SPS-610C
BXI-2008D
(2) SWR-1242D / Ported
  • Who's Online   0 Members, 0 Anonymous, 1014 Guests (See full list)
