Subwoofer options/Limited space for ground pounding bass
unless you have more space (and able to give the port clearance) i dont think youll fit 2x 15
you could do 4 10" in the same space and have more cone area
if that is something your interested in
sorry, I just did the math 3 times too and I got something different ( 36 x 22 x 20) / (12 x 12 x 12) = 9.167 ft^3
I just woke up so I apologize if I'm wrong :P
Internal useable airspace are inner dimensions though. 34.5X20.5X18.5.
You are right but that's the external volume, if you take away the wood displacement you get the 7.5 cubes which is the gross internal volume. Learn Torres takes away the number crunching.
20h x 22d x36w
yes it 9.1cuft of area
but 7.57 cuft gross with 3/4" mdf
but you need to allow clearance for port unless you do port up
with a 3.5" port youll need 3.5" of clearance leaving you with 18.5" d @ 6.5cuft gross
after a double baffle front 6.3gross
Box gets small pretty quick
so with a tune of 30-33hz you only have 4-4.5cuft net to work with
gotcha! I was just using my phone lol, it's always a hassle to boot up windows to use torres lol. Macbook FTL
my 1 set up for the last couple years has been a pair of jl 13w1 subs running 2ohm off an mrp-m500 , in a sealed box and i thought the performance from this package was pretty alright .if space is an issue i would start thinking about making something out of fiberglass to maximize the space available . being a hatch car it shouldn't take too much to get some volume
Ok cool. Fiberglass is an expensive option but well worth it I have heard. Clean looking and soild if done right.
fiberglass is kind of expensive , but when you think of $100 dollars for a prefab box that makes the supplies for fiberglass look like more of a value , $45 for a gallon of resin and $30 for a big chunk of glass mat .a gallon of resin can go a little ways if you know how to work it .i guess for the expensive part of fiberglass has been learning how to do it .
Just buy a good 15" sub and a build a ported box (32 Hz tuning, don't need to go lower).
You have 1000 w rms to play with. It is not a lot of power, but you can have good results with that power.
With that budget, you can find a used Fi btl or a good DC sub. You will upgrade your amp later, but it will sounds good even with "only" 1000 watts.
black BMW X1 2.0 l 192 hp
OEM head unit, Amplifiers :  Audison AP 8.9 with integrated DSP and Ampere Audio 1200.
Focal ES 100 K in front doors, and Dayton RS 180 for midbass under the front seats.
2 SSA DEMONS 10" subs, in a sealed box. SecondSkin Damplifier on front doors, and Luxury Liner Pro for the cargo area.
Fist ground pounder requires cone area and a single 15" has less then 2 12"
Second he only has 500w x2 not 1000
So he need 2 subs as he can't strap them amps
What ever he choses need to work within 4-4.5net as a total
Options
4x 10" on 250rms Ea
2x 12" on 500rms Ea
1x 15" on 500rms
If you can get a bit more space 2x 15" will work
Spent about 30 seconds vaguely crunching number in the Torres calc. You can fit two Sundown SA-15"s if you wanted to.
On 6/30/2011 at 1:11 AM, 'Ray' said:
Acoustical energy is free. Electrical energy is not.
