last night while driving home my sub starting sounding really hollow, and like it was flapping.
upon pulling the 4.4 cube box out of the trunk (by my damn self -.-) this is what i've found...
well... time to finally go through with building this new box right?
'08 Chevy Cobalt coupe 2.2 base model trunk build:
2 9512iSC flatwound alum 1.5 coils
-extra 9500 spider pack
-8" platinum carbon dustcaps
1 DD Z1 (.375ohm nominally daily)
3g31 AGM
320a Ohio Gen alt
1 DD S4 4 channel
4 VO-M8v1's (holes cut for 3rd pair)
2 CS 6.5's
2 VO-B1's
Sony XAV-601BT
all Knu Krystal RCA's
Cadence 7band EQ
______________________
148.3db @ 32hz (burp)
148.4 @ 37 & 38hz (burp)
146.xdb 90sec average (center windshield)
I'll give you the kool aid man...
OH YEA!
What happened were those the wrong screws, not enough tite-bond or what?
98' dodge ram
140A alt
Big 3
XS D2700
JVC kd-r310
Rockford T500-1BDCP
2 Sundown E12 Ported 4cubes 35hz
Rockford P400-4
2 Infinity reference 3way 6x9
2 Polk DB 5 1/4
2x layer dynamat all doors
well... long story short, i trusted someone to build me a box that i shouldnt have.
im surprised its lasted so long, but it looks ike it didnt have glue on that top plate -.-
3g31 AGM
320a Ohio Gen alt
1 DD S4 4 channel
2 CS 6.5's
2 VO-B1's
Sony XAV-601BT
Cadence 7band EQ
what glue did you use? thats fixable
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
looks like there wasnt any glue used.
just some screws and caulking to seal -.-
3g31 AGM
320a Ohio Gen alt
1 DD S4 4 channel
2 CS 6.5's
2 VO-B1's
Sony XAV-601BT
Cadence 7band EQ
That is why I wood glue all of my joints both inside the box along seems and on the surfaces that make contact in the joint. I use hardly and screws in my boxes (compared to most people here) to help maintain the integrity of the wood or MDF sheets themselves and have never had problems.
I'm gonna hate
unscrew everything and pull it apart and clean all the surfaces and use some good wood glue and reassemble it.
Should be better than it was before but make absolutely certain you got off all of the caulk, if you have to put the side that faced inside and switch them to the outside so you have a good clean surface for the glue to penetrate and then carpet it after you finish it.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
instead of inverting each surface, couldnt i just use a damp rag to clean the surfaces and let it air dry?
Edited by Robby Holmes
3g31 AGM
320a Ohio Gen alt
1 DD S4 4 channel
2 CS 6.5's
2 VO-B1's
Sony XAV-601BT
Cadence 7band EQ
