Please Check My 4th Order Blow Through!
Here is the sealed side.
Here is ported.
and the sketch up model I did.
Please let me know what needs to be fixed or if I actually did it right! The port is 14" long and the enclosure is for 2 Sa-12's. Let me know! Thanks
My Truck Build
Spending money on things I don't need, to impress others I don't know.
At the end of the day for me its about the love of customizing anything and everything to limits or even past reasonable.-SkyHighCarAudio
Looks good to me.
Edit: just make sure you know how much of that port needs to poke forward of the box to complete the transition into the cabin from the bed, and design accordingly. The less port you have inside your box, the less displacement it causes (i know i know, sounds stupid, but sometimes people need the reminder)
Edited by Sanitarium
I wouldn't cut a square into your truck's metal ... your acordian boot will not go on and seal properly and leak water like crazy ...
my suggestion would be to oval shape it or something ...
I graphed the box in bass box pro and it Isn't very flat. Cuts off at about 46 hz. One note wonder. I heard the sa12s aren't very good in a 4th order. What do you guys suggest I do? I really want to stay with sundown.
My Truck Build
Can you post a screenshot of your graph in bassbox pro?
Vehicle
2007 Chevrolet Avalanche(Co-Co)
DNX9980HD
6 Team Fi 15's(King Edition)
3 DC 9k's
8 Nendo PWX 8's
4 Custom Steg 4" Super Tweeters
1 DC Audio 175.4
1 DC Audio 90.4
Rockford 360.3
3 DC Power 370xp Alts(Externally regulated)
21 D1600's
2 D4800's
All SMD RCA's
AudioTechnix Deadner
Viper Alarm
My YouTube- http://www.youtube.c...NG?feature=mhee
Link to buildlog- http://www.stevemead...4-15s-2-dc-9ks/
Link to UBL- http://www.stevemeadedesigns.com/board/topic/165059-ublkings-avalanchecoco-new-build-starting8-king-edition-15-team-fis-in-a-wallyes-a-wall/
I have a strange feeling that this style enclosure is not going to give you the output you desire ... Most people doing a blow through usually runs 4 15s or better for massive output through the port ...
For nothing larger than a pair of 12s, I would suggest a more simple ported style enclosure like mine using the front baffle as the back wall instead of a "blow through" port ...
That way you can adjust to your desired tuning instead of settling with a "one note wonder" port, or extreme low tuning ... I also would suggest a nice 32 htz tuning for those drivers for a tad bit of SQ and a healthy amount of SPL ... That enclosure being mated to the back wall cabin area should give you a very nice "gripping your throat" deep bass like mine ...
Then again. Just my suggestion here ...
That right there is a great answer. The problem is I don't really want to cut out the whole back wall .. Is there anything that can be done but without cutting out the whole back wall?
My Truck Build
The paper work sundown provides say they are well suited to 4th orders.
  • Who's Online   1 Member, 0 Anonymous, 1091 Guests (See full list)
