i am running a dc audio 3.5k and keep blowing fuses when i go for my run.
I run in meca in s3 class i have two 15" lvl 4 dc audio with a 3.5k on them. i have hit 147 sealed with the 3.5k but have a problem doing when i change my fusing when i am run meca. When i am runing meca i have to use a 150 amp fuse its an anl fuse if you were wondering. But when i do use it, it only last a second or two at the most and dont know why. My class i run is s3 i have two 15" lvl 4 dc audio m2 with all lvl 5 parts on them. Direct leads on the subs and copper coils. To stay in my class with the 3.5k i have to run a 150 amp fusing to stay in my class. If i put a bigger fuse in i will be pushing in to the next class. The problem i am having is when i go up to run the fuse only last a second or two at the most. What i do when i run is i turn my head unit at the volume i am going to staying at the then i turn up my gain knob. But before i can realy turn up the gain the fuse blows and it has done that every time i go up to run and not realy sure why. But know i am going to getting ride of my 3.5k for an american bass 500.1 or a dc audio 5k but sure which one yet. I am guessing that i will have the same problem i am with my 3.5k because the 3.5k takes a 300 amp fuse for total power. and the other amps take like 400 amps or more to run them at full power. So if you have any info i would realy appreciate it thanks.
you gotta cook it a lil longer :D
151.6 with single 12 at 41 hz
153.2 with 2 12's at 43 hz
power: dd m4
gotta love meca :)
I use 160amp (2 - 80 amp) fusing on my ab500.1 @ 0.5 ohm before without issues.... I roll my volume though....
I'm also in S3...
My Build Log- T E A M S U N D O W N A U D I O -
2013 DbDrag WF SS1-2 - 5th Place 154.6db
2013 MECA Mod3 CA State Final Champ 153.4db
Powered by: Sundown Audio
I burp my dd m3 at .5 on 60a and get a fine burp...im guessing your clipping quite a bit or having nasty voltage drop due to inadequate electrical
Team Flex Issues
Low tuning > God
2011 CALI AS1 STATE CHAMP
