Kinda a weird question but I bought 2 DC level4 xls almost a year ago now. and i still havent hook them up. My question is will they get damaged from just sitting there not being used? rookie question but ive never had subs just sit for this long.
as long as they're inside and not in a humid/dry/hot/sunlight condition..
inside the house in the boxes is fine.. outside.. you will be looking at dry rot on the surrounds and heat damaged spiders i would imagine.
09 Civic EX
KDC-X395
(2) SKAR Audio VVX-12
Skar Audio SK-1500.1
4 cu ft @32 (new box and more port soon)
Firing Forward not sealed off
Stock 80 Amp Alt
Big 3 In 1/0 Knu
2 Runs To The Back 1 Pos 1 Neg In 1/0 Knu
DD-1'd 13.8v drop
gonna have to say no.
Driving my 2008 Dodge Ram 2500 MEGA cab with the 5.7 hemi.
Audio: Two 10" Alpine Type R's ( 1000rms models )
Hifonics BRZ 2400.1D @ .5 ohm
Two Kinetic 1400 batteries ( soon to have XS power under hood )
Tsunami 1/0 Awg wire throughout truck.
Stock Infinity 7 speaker system ( Junk ) soon to be replaced, probably all Alpine.
Exterior: 17"Dick cepek rims with 33" Toyo MT tires
Bushwacker fender flares
Magnaflow true duel exhaust
LED tail lights with Projector headlights
Plasti-dip fun coming soon!
In the house they're fine, left out exposed to some elements then the surround can dry rot eventually.
And the fact more than one person agrees does not make it a circle jerk, it makes it a bukkake scene and you're in the middle ;)
Chick took 3 shots of Jager, and then, pissed in my mouth..
B5 Passat Build Log
i had an orion h2 sub sitting in my closet for a while. It was perfect working condition when i put it there. When i took it out, the motor was shifted and locked up the voice coil. When i took it apart, i found that the motor was only glued to the frame, and the glue had failed. I dont know if the dc sub is made this way, but if its bolted up, it should be ok.
99 GMC Suburban
2 Death Penalty 21"
2 Crescendo BC2000
Boston GT-42 Amp
6 Selenium 6w4p
4 Crescendo tweets
Hi output cs144 alt
Audiocontrol Epic-160
Pioneer DVD head unit
If you neglect them for too long they'll begin to suffer from chronic depression, even suicidal thoughts.
It just isn't fair to deny them of their potential. And doing so, can lead to irreparable emotional distress.
2005 Subaru Outback Wagon Pioneer 9400BH Fi Q 15, SAZ1500dV3
The first build>>> http://www.stevemead...-outback-build/
140.9 @ 36hz Sealed on dash!
REBUILT!!! 2 Fi Q 15s, 2 SAZ1500dv3 146.9 @ 39hz dBDRA certified
This ^
And depending on the climate where you are, even being stored inside can cause mold/mildew to form on the surround and spider if it's humid.
Storing them with the cone side down would also be a no-no
  • Who's Online   0 Members, 0 Anonymous, 1746 Guests (See full list)
