ZachG Posted August 15, 2012 Report Posted August 15, 2012 Ok so I read here how to figure out my output voltage for my amp and how to set the gain. http://knowledge.sonicelectronix.com/car-audio-and-video/car-amplifiers/how-to-adjust-amplifier-gains-using-a-digital-multi-meter.html The number I came up with is 57.67v My amps birthsheet says it does 1,663rms at 2 ohms. Before I go and set my gain on my amp to this I just want to make sure this is correct 1998 Pontiac grand prix gtp supercharged2 12" Obsidain Audio V.1 on a 2011 zx1500.1 at 2 ohms. 20ft of Knuconceptz CCA 0 Guage. 2nd Battery is a Shurken BT-120. Box is 3.5cu tuned at 31.8hz sealed off from the trunk. 14sqft of Dynamat on the Rear deck top & bottom. Soon to be more for doors/roof. Gets low & loud Did a 140.5 Sealed at Battle of the boom in June 2013 dropping to 12.7v (need a alt mines going bad)
ZachG Posted August 15, 2012 Author Report Posted August 15, 2012 No one? 1998 Pontiac grand prix gtp supercharged2 12" Obsidain Audio V.1 on a 2011 zx1500.1 at 2 ohms. 20ft of Knuconceptz CCA 0 Guage. 2nd Battery is a Shurken BT-120. Box is 3.5cu tuned at 31.8hz sealed off from the trunk. 14sqft of Dynamat on the Rear deck top & bottom. Soon to be more for doors/roof. Gets low & loud Did a 140.5 Sealed at Battle of the boom in June 2013 dropping to 12.7v (need a alt mines going bad)
HunterJohnson Posted August 15, 2012 Report Posted August 15, 2012 dont set ur gain with a dmm. Scion tC SQ BuildiPad mini, lots of fabrication, daily drivenFord Explorer C Pillar Wall Build Just a cheap car to destroy with bass
CJ18 Posted August 15, 2012 Report Posted August 15, 2012 Not accurate. Do not rely on this. Go to the tools section here and check out the dd1. That is what you need to properly set your gains.
BASS_ZEALOT! Posted August 15, 2012 Report Posted August 15, 2012 dmm? this is PREPOSTEROUS... GET A DD-1 DONT BE CHEAP STEP YOUR GAIN UP !!! DD-1 SMD makes the best products! I bought them all! Click the banner below!
fosgatefan821 Posted August 15, 2012 Report Posted August 15, 2012 dd-1 or o-scope . is the only way I would do it 2007 Ford Ranger (ALL YET TO BE INSTALLED - DUE TO WORK SCHEDULES) K&N Performance Air Intake Massive Audio D2400 Mono Amplifier 2 Custom Built 8" Subwoofers in Ported Enclosure Pioneer AVH-P4400BH In Dash Double Din DVD Player (Video Bypassed) 4 - Pioneer TS-A6886R 6" X 8" 2 - SMD Heavy Duty Single ANL Fuse Blocks 2- Stinger SPP1200 Dry Cell Batteries JL AUDIO Interconnects 2/0 Gauge Big 3 ILL Customz 8 Spot Flat Lug Style Bolt Down Terminals ILL Customz 1/0 to 4 Gauge Power / Ground Reducers Factory Alternator __________________________________________________________________________________________________________________________________ 2002 Cheverlot Monte Carlo SS - (Deceased) 2 - Rockford Fosgate Power 1501BD 1 - Rockford Fosgate Power 851x Rockford Fosgate Power 6 1/2 Components Rockford Fosgate Power 3 way 6x9 2 - JL Audio W7 13.5" Subwoofers (Sealed) Pioneer AVH-P4400BH In - Dash DVD Player Pioneer AVIC - U250 - Add-on GPS Navigation System Audio Control 6XS 4 Way Crossover / Line Driver Ohio Generator 200 Amp Alternator 3 - Stinger SPP1200 Batteries 1 - Optima D34/78 Battery
ZachG Posted August 16, 2012 Author Report Posted August 16, 2012 A dd-1 is like 170$ That's a lot to use it a couple times, how bad could it be if I used a dmm 1998 Pontiac grand prix gtp supercharged2 12" Obsidain Audio V.1 on a 2011 zx1500.1 at 2 ohms. 20ft of Knuconceptz CCA 0 Guage. 2nd Battery is a Shurken BT-120. Box is 3.5cu tuned at 31.8hz sealed off from the trunk. 14sqft of Dynamat on the Rear deck top & bottom. Soon to be more for doors/roof. Gets low & loud Did a 140.5 Sealed at Battle of the boom in June 2013 dropping to 12.7v (need a alt mines going bad)
Kyblack76 Posted August 16, 2012 Report Posted August 16, 2012 A dd-1 is like 170$ That's a lot to use it a couple times, how bad could it be if I used a dmm Only as bad as setting it with your ear hole....... cheers and good luck.... SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
BASS_ZEALOT! Posted August 16, 2012 Report Posted August 16, 2012 ITS A DD-1.... OR A NEW SUBS YOU CHOOSE ! SMD makes the best products! I bought them all! Click the banner below!
n8ball2013 Posted August 16, 2012 Report Posted August 16, 2012 While you will see that alot of members will advocate using a dd1 or oscope this is better than nothing. Its a crapshoot at best though. I have a scope and a dd-1 and i really prefer the dd-1 its just so simple. THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
