Found it!
It's 11.5" long and will work up to 4/0. PM me with info if you want it ;)
glad you won't have a better sitting just above your signal processor :)
Oh hell no!! :D
Found it!
YGPM
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
I recently ran into this issue and i stripped and soldered the 2 ends together. It was not pretty. Had a big solder buldge that I then had to grind down. I like the 1/0 connector idea then maybe shrink wrap on top of that + etape and loom. A few other good ideas in this thread.
Your way sounds like a pain lol
Yeah, it was a pain, I wouldn't recommend it at all.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
I didnt read through all of the replies, but I had the same issue. What I did was add a volt and amp meter in between. It connected them and I was able to run the extra run of 1/0 wire that I needed. I mounted the meter to my subwoofer box so I could see the amp and voltage, but the the issue is, I would have to be on the passenger side of my rear door to see it. I got it for the issue that you are running into, not so I could see the meter, but it did its job. You wont loose any amperage or voltage. Only amperage or voltage loss would be from the length of your wire, which I experienced at .4 volts. But Im not sure how accurate that was, because the voltage meter I was using at the battery, was one of those blue LED digital voltage meters you can get for $12 off of ebay, so no telling if its dialed in or not. Either way, that's what I would do. Plus if its in the right spot, you can see your voltage and amperage.
Its made by XScorpion. Its a XScorpion DAV02P. Pretty cheap solution for $25.
Here it is
http://www.sonicelectronix.com/item_38978_Xscorpion-DAV02P.html
  • Who's Online   0 Members, 0 Anonymous, 4546 Guests (See full list)
