Hey guys i was looking on ebay and saw this sub, it says its imported from USA, so i thought i might ask u guys if its a big brand over there.
well heres the link,
http://cgi.ebay.com.au/NEW-P-TEKNIQUE-ICBM...1QQcmdZViewItem
its a P-TEKNIQUE 2000W max subwoofer, 800WRMS, just wondering is it worth buying like 3 of them to use?
1 12 inch infinity 1240watts...only can fit that in a hilux single cab...
1 infinity 1000 watt mono block...
2 Hifonics Zues 6.5" Components
2 Hifonics Zues Tweeters
2 cross-over boxes
1 run of 4GA
200 Fuse
1 Kenwood Head-deck
I dont know what $120 au dollars is compaired to us dollars, but if its around 120us, I wouldnt waste my money.
The subs are cheap, made to look good (like audiobahn) but worst performance (even tho performance is in their name).
I know a guy that had 2 of their best subs back in the day and they sounded like straight crap in his ford probe gt,
To say the least, you are better off with your infinitys.
Just build a good box for them, and it will sound as if you had a new setup.
At least Id personally take the infinities over the pt's
i know a guy that had some in a civic. they where decent loud for the price he paid, they sounded like crap though. he beat the shi7 out of them and they didnt blow, not yet anyways. yeah your infinities are better, just make a new box for em and you will be set. btw is the box your running a sealed common chamber? build a new ported box and you will be happy with its output compaired to your current box.
1992 cavalier build
1992 blazer s10
kenwood cd
hifonics hfi2500d
6 soon to be 12 12" hifonics hfi12d4's
shit ton-o-wire
Blurred Vision Audio
Team SMD
feedback/refs. clicky!-
dont buy it, its garbage :lol:
H/U Pioneer deh80prs w/ HRT iStreamer Ipod DAC
Front stage is active, 4 Morel Elate 6.5" & 8 CDT DRT26 tweets
amp running 4mids, Mosconi Audio 300.2
amp running 8tit & alum tweets, Mosconi Audio 200.2
8 12" Ascendant Audio Chaos. amps 2 Digital Designs M4'z
box is a 4th order band pass
batts. 1 XS Power D3400 under hood,6 D3100 in back
2 XP 370 amp DC Power alts.
MLA module 15+volts
All in a 97 2door Tahoe LT
2010 West Coast Reg. 140-149.9 Bass Race Champ
Team Bass Hz
i posted a topic about building a box for my 2 12"s i don't know how to work the port out, osme1 has explained it but its to confusing i might go buy a twin 12 ported box from an audio store
2 cross-over boxes
1 run of 4GA
200 Fuse
1 Kenwood Head-deck
Trust me, the infinity subs you have can get loud. You just need a good ported box to do it. I have the older model infinity reference series 12" subs, 2 of them. Powered by an orion 4002. I had it metered before on a much smaller amp and did a 137.9. They need right around 2 cu. ft. of air space each, tuned to around 37 or 38 hz. For us to help you design a box, we need to know the maximum dimensions you have available to fit a sub box in. We can design the box and figure port dimensions for you and all you have to do is cut the wood to the dimensions we give you and assemble. Also, port tuning is not something that is easily understood, so if you don't get it, it's ok.
ok ill go measure now, i only have Millimeter tape measure as im in Aus, is that ok?
2 cross-over boxes
1 run of 4GA
200 Fuse
1 Kenwood Head-deck
You are buying a New P-Teknique High Power 2000W Subwoofer, model ICBM5912. Top of the range 12" Competition woofer designed for high power applications.
Directly imported from USA, now you can enjoy these great offerings from P-Teknique right here in Australia.
To find out more visit:
http://www.performance-teknique.com/
FEATURES:
2000w max power, 800w RMS
4 ohm
3" Heat Resistant Voice Coil
Huge Magnet Structure
Semi-Press Cone
Die-Cast Aluminum Basket
Flexible Rubber Surround
ChromeAluminium T-Yoke
Push Type Terminals
Frequency response 30Hz - 500Hz
Sensitivity 89dB
Specifications:
Mounting depth 189mm
Mounting hole diametre: 302.5mm
Net weight 17kg approx
Qts: 0.2952, Qes: 0.3102, Qms: 6.0907
Sd piston surface area: 0.0471mm
Vas: 29L
I see that was the first thing you said, Imported FROM usa, but no, they are not made here, maybe shipped to USA, and then shipping elsewhere, but they are definitly built in china
Other thing that caught my eye was the fact it has a HEAT resistant voice coil... ohhhh boyyy
