Lack of high notes in 4th order
srool
I have built a 4th order bandpass for 2 DC lvl 2 m2.
the box is in 1:1.25 ratio, for better bandwidth. and tuned to 45 hertz, single rounded 4" diameter port on a 1.25cuft of ported volume (means about 10 cuin of port area on each 1 cuft of ported side volume).
I havn't measured yet but the lows are much louder than the highs.
What do you suggest to do in order to have better highs ? change the port lenght ?
tune it higher, i like 50-55hz
by shortening the port length,
my opinion is get a termlab or hire one, get a few test notes, and go at it
measure what you have and see then cut it shorter slowly until you get a happy medium
Tune it higher, in the 50s, how much power are you running toward them?
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
Considered adding more midbass to your front stage to handle it? If you like the sound otherwise from your 4th order this may be a better route... remember that all adjustments are give and take, so you may loose a little amplitude in the lows tuning higher or possibly end up just throwing the whole damn thing off.
2007 Pacifica
I tried to enlarge the bandwidth by low ratio and less port area.
Didn't expect so much lows but really like this as this setup is mostly for demonstrations.
I run them on about 1200 RMS.
I have my own SPL Lab meter so I'll find the time to measure it.
as for midbass- I have SQL setup- DLS Scandinavia in a 13 liter ported boxes.
Isn't additional port going to shorten my bandwidth ?
Increase the port to test and see if you like it, it will decrease some of the lows and make the box a bit more musical.
Kenwood H/U
1/0 wire,
You would have had better luck with a 2-1 ratio, mix of both, ive never done something to a similar 1-1 ratio always have been 2-1 or 3-1.
Kenwood H/U
1/0 wire,
I would tune higher, would hate to lose those lovely little lows though. you know bitches love lows, right?
What the f**k is an appropriate signature supposed to look like?
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
Rockford Prime 200.2
Pioneer 6.75" Comp Set
XS S3400, D2700
Project DB Battery Terminals
Axxess ASWC
Stinger HPM Everywhereeee
90 Sq. Ft. of Stinger Roadkill
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/
My Old Build: http://www.stevemead..._+2000 +mustang
Avatar Courtesy of SnowDrifter
  • Who's Online   1 Member, 0 Anonymous, 649 Guests (See full list)
