What would happen if..............
So i have 3 SK_BT120 battery's backed by a 220amp alt powering 2 15" Zv.2's off a SAZ-3500. I want to know if i can use a LM317 variable power supply (Google it if u don't know what it is) to boost the voltage on my bus bar while im in the lanes competing, my concern is all my bats are 12volt would it hurt them to have 15volts for a short period of time? and is this even feasible with this product? its cheap that's why im asking.
From what I've read, I don't think you want to charge 12 volt batteries over 14.4v.
Perhaps someone with some more knowledge could help you more,
97 Suburban
8 custom PSI Platform 3 18's
Most cars charge the battery to 14.4v while in operation and rest at 12.6v without a load applied, So yes, 15v would be ok, however, increased stress and heat can cause hydrogen vapors to be emitted from the electrolytes, but you should be good considering you said it would be for short amounts of time.
Just be honest, it's always a work in progress with ever changing plans.
im pretty sure that this is against the rules while in the lanes. outside of the lanes no big deal but I dont think they'd let you get away with it during a run.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
from what i can see. u can adjust the voltage but u cant BOOST it higher than what the car charges at? if u want to boost the voltage you would need to change or manipulate the regulator on the alt
2002 ford focus hatch
pioneer DEH-P8400bh
infinity kappa 6.5 components front and rear
XS Power D1200
Shuriken BT-100
audioque 120.4
2 15 inch audioque HDC3 D2
2 audioque 2200d
big 3
mechman 220a alt with external regulator
479-418-3056
When i compete i dont touch my voltage.. Depending on what mids amps in truck i chage anywhere from 14.8 to 15.2 ( adjustable And old school amps dont like 15v so iturn it down for them)
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
  • Who's Online   0 Members, 0 Anonymous, 945 Guests (See full list)
