depends on what you have running already and what you want to do
2008 BMW 550i M Sport
Build coming soon!
2000 Volvo s40 1.9T
Pioneer DVD navigation head unit
O2 audio performance mid range speakers
2 Crescendo PWX-6 Pro Mid Range Speakers
2 Crescendo PWX-8 Pro Mid Range Speakers
4 Selenium ST200 Super Tweeters
Hifonics ZRX2000.4 Amplifier
2- 12 inch DC Audio Level 4 m2
Hifonics Brutus BXI-1610D Amplifier
2 KinetiK HC1400R- Secondary Batteries
Kinetik HC600- Secondary Battery
Knukonceptz 1/0 gauge big 3 upgrade
if you have an rca running already and want to split it in the back then just use 2 1 female to 2 male rca's.. make sure they're long enough to reach your amps tho
Build coming soon!
2000 Volvo s40 1.9T
Split the white into 2 , and the red into 2, one set for bass amp, other set for 4 channel. You want to make sure the left, and right signal is correct, or else you mids and highs will sound reversed.
2003 Kia Sorento
Team Subsonic Lows
Team Bassin' on a Budget
you need 4 male plugs, and 2 females. unless you're gonna need another couple RCA's then you want all female.
Just say no to Ground Pounder Customs.
More box builds
some cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches!
I'm with captain stupid.
or you can buy a $50 eq with all the outputs.. 2 l7 will over power your stock mids so get a 4 channel amp hooked up
well ive got aftermarket mids/highs, just the lame stock 4 channel.
2006 Ford Explorer
2 Team AA/Sundown 15s
6th order
Ct Sounds 7k
4 PRV Mr500 8s
Rockford p1000-2
Team Subsonic Lows
i would still get an eq.. you can control your sound better and when you have only 1 RCA output on the deck its harder to adjust the sound.
I wish i knew how to use an EQ.
More box builds
  • Who's Online   0 Members, 0 Anonymous, 1046 Guests (See full list)
