bighoss' 2006 f150, truck is gutted
going to be ran active on my c1100.4
Why go active over passive? Louder? Cleaner? More efficient? I see people going both ways (insert sinister comment here) and am deciding which I should go with for myself.
Are you going active right off the bat or trying passive first? You already know what you want? why/how?
Thanks
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
Thanks
Active only, I dont see how I could sun a passive set up even if I wanted to with 8 mids and 2 tweeters, the tweeters will be bridged on channels 1&2 and will be getting around 300w each and 4 mids on ch3 and 4 mids on ch4 getting 75w ea. Right now the mids are bandpassed from 120ish to around 5k hz when I get the tweets in I might change it up to see what sound the best.
Used to have a loud truck
found the problem, one of the 3500's is stuck in protect. And its the one on the bottom of the stack fuuuuuuuuuuucccckkkkk
no clue, the other 3 still work perfectly fine, the amp in protect is the one I was using back on the 2 18 wall so I was using it for almost a year with no issues then it randoms decides to go into protect.
When I had an amp issue it was the one on the bottom. Before you pull it out make sure that you test it by itself and see if it still protects
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
will do, what was the issue with yours?
No idea I just know it worked when I pulled them so there was no weight on the bottom one. I added another tiny spacer between the amps because j think it cause the case to ground out on the aluminum supports that were bolted to the truck floor
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
doubt thats the issue with mine, I have a sheet of mdf on bottom, 1/2" nylon spacer, c1100.4, then the 3500 that is stuck in protect. At first I didnt think to check to see if the protect light was on since the rca's from the h/u go into this amp and then are daisy chained to the other 3 and the others are working fine
Well thats gonna suck. Maybe youll get lucky and its the rcas
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
