bighoss' 2006 f150, truck is gutted
I know the electrical us weak, this is damn near the same wiring from when I was running 6k lol. A few pages back I said I was.gonna do the electrical before I.do anything amp wise. I'm keeping the same batts and my singer 350 but will be adding 2 mechman 320's and do the wiring. I know I'm gonna catch hell for saying this but I'm either going with 3+ and 3-runs of shca ofc 2/0 from the front batt and 1 run.to the back from each alt or 12+ and 12- runs of execution audio cca 1/0 from the front batt but I'm sticking with ofc for for the alt runs and the runs to the amps. I havemt had any problems with the small charger. After a few days on the charger they rest at 12.9-13.1.
That's 12.9-13.1 of surface charge, you can't charge all those batts off of like .25a of current, seriously. That's why the drop in the rear is so substantial because the surface charge gets torn off and then that .4-.8 drop is them charging. Your stock alt biting it just highlights that as it was charging non-stop, an HO won't last nearly as long as the stockies can run under load far longer as they generate way less heat. Ed has good deals on XS chargers on FB, go get one.
2 runs of OFC 1/0 for each alt positive is plenty to the batt (unless you are running to the rear then 2 is about right as the runs will be like 17'), but just do the grounds to the frame, lots of them and it's way cheaper than another 100ft+ of 1/0.
If at first you do not succeed, you are doing it wrong! -ARS
Check out my walled TBSS build over here
4 Fi Team 18s on 2 Cactus K9
DS18 doors on 2 MBQ 1Ks, Vifa pillars on a STL4.500
Pioneer X8500
6 XS Power D7500, 1 3400S
Second Skin
2 270a Mechman Alts
Hmmm. What charger under $100 Would you suggest then?
Used to have a loud truck
I dunno for under $100 man (you have my favorite cheap charger like I said I have the same one)... You could get more of the one you have and run them all at once (3 more for 12a total?). I just bit the bullet and dropped $270 on an XS. There has to be some that will do 15a+ for $100, just don't know of one personally.
Pioneer X8500
Second Skin
2 270a Mechman Alts
I use a ctek 7002... charges 7 3100s fine
Might not be a speed charger but just put it on over night
right now Im using a ctek 3300
Not really a rebuild just beefier subs and more power
True enough, I remember reading that earlier now that you say it.
Give me your Paypal and I will chip $5 towards shipping if you go with Mayhems........just sayin.................................................now what
Sweet. Only $495 to go lol. I'm gonna go with the hems unless I can get the tantrics for a lot cheaper
half a grand for absolutely nothing. ouch. The thing will be slammin no matter what you choose. Might be cheaper to go pick up the subs, lmao
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
Im in the process of strapping at .5 right now..... will be burping next week
Well when I get to 750 posts, I can tell you I have two Mayhem's and two 3500's you might be able to use...lol
Soooo, I just burped it at .5 strapped with some uncharged batts...... amps didnt protect but voltage dropped loooooow and I have some new meter numbers
no one wants any .25 ohm numbers?
