mounting sub to baffle question
gt58
im building my box today and im not sure if it is necessary to use t nuts because i do not plan on removing the driver. im only at ~800-900 rms. are wood screws sufficient if i do not plan on removing the sub. like i said its not crazy power but i would still like to be safe if necessary. what do u guys think
edit: im using two sheets of 3/4 mdf for the front if that makes any difference
you do not need t nuts
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Yea they are probably fine. Are you mounting it sideways or vertical and what kind of sub. I used em on my sa-12 about the same power range...sub was even inverted for a while. Make sure they have a good bite and penetrate into the second baffle.
MY BUILD *****http://tinyurl.com/gmcbuild*****
Vehicles
2005 GMC Canyon
CB1000r - Currently where any future funds are going. (exhasut,bazzaz, ohlins shock, screen, etc.)
crf250r - Used to be race bike..now I just trail ride..practice at the track on it.
CH80 - Daily beater (when nice weather)best 150$ ever spent. 100+mpg
Sold to:
Skullz - pstone11 - Leo1103 - Volvo 63' - pavelpardo - imnew59585
Shower farts still piss me off.
I think theyre pretty neat. When the water runs down your crack as you let one out... its like shitting in a crockpot.
sub back
another question would be, since i am using drywall screws for the sub every 5 inches or so, if i have some left overs, are they ok to mount my woofer? i know people snap the heads off and that would suck, or should i get some stronger screws. also should i have some of the screw come thru the baffle? ex. 2 inch screw would stick out approx .5 inches
sub back
It wont hurt if it pokes through the baffle. I've used drywall screws before. No problems with snapped heads for me. My last setup the screws barely came through the baffle. If you are doing a plexi window its not desirable but it wont hurt anything
Vehicles
2005 GMC Canyon
Sold to:
No way you'll need to use t-nuts...you can probably pull the sub in and out of the box as many times as you want and really not worry about it. Deep subs with big motors are another story though, since those put more pressure on the mounting screws.
Ryan Miskin - owner of RAM Designs
I have my PM's turned off, please email at <script data-cfhash='f9e31' type="text/javascript"> /* */</script>
2200+ designs since March 2011...
i just finsihed the box today, that woofer is a beast, 50 lbs. i ended up using the drywall screws.
on a side note, its killin the lows now :))
once you start pulling screws/snapping screws from the baffle (usually only big boy subs) then you need t nuts, and usually the subs are mounted vertically so more weight is pushing on the screws.
but for you, you dont need them.
  • Who's Online   0 Members, 0 Anonymous, 3388 Guests (See full list)
