bighossf150 Posted September 9, 2012 Report Posted September 9, 2012 I used my dd1 when I first set my amp back in april but I redid my wall since then and must have accidently messed up the settings on the amp because the subs would start to stink after 15-20 sec of playing full tilt, so I went back and reset the gain with the dd1 and now its noticeably quieter, I went from doing a 151.1 before to a 145.3 now after resetting the gain with the dd1. Both times were with the -5db track. It was with the truck off and my 4 chan amp disconnected. Any suggestions? Used to have a loud truck 2009 Corvette Z06, H/C/I, 150 shot, g force tune, 730rwhp/690rwtq 2013 F-150 limited, MPT Tune, leveled on 35"s
tctdh11 Posted September 9, 2012 Report Posted September 9, 2012 Do it with the truck running TEAM DC www.dcsoundlab.com 2003 Tiburon GT V6 6 Speed Ported Clam 6 12" DC Audio XL M2's 2 American Bass 1100.1 1 American Bass 350.4 3 D3100, 1 D975, 3 D925 Second Skin Damp Pro and Spectrum. About 75% done 153.6 Sealed on dash at 34hz My OLD Build Log New Build Log.. DC XL M2 4th Order in my Tiburon
TRTC360 Posted September 9, 2012 Report Posted September 9, 2012 Do it with the truck running I highly doubt having the truck on or off would make even a 2db difference with insane voltage drop, there's something else going on, can you be more specific with the system? Give us some details. '93 Firebird Formula V8 H/U- Kenwood eXcelon KDC-X395 Mids/Highs Amp- Hifonics ZXI80.4 Wiring-KNU RCA's, Speaker Wire, And Two Runs Of Trystar 1/0 G34 Red Top and a 180amp Ford Alternator www.youtube.com/TRTC360
gally Posted September 9, 2012 Report Posted September 9, 2012 maybe it is louder because of the engine noize 2010 Chevrolet Cruze Radio --- pioneer mvh-200vbt Front/back --- alpine type s 6.5" Sub Control --- Pac LC1 Sub Amp --- GZPA 1.4K Sub --- GZNW 15XSPL D1 Battery - GZBP 12.2500X
Swordlordboy1234 Posted September 9, 2012 Report Posted September 9, 2012 Why did you tune -5 db which is the SQ setting and working on getting higher numbers. My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37 My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/ 2016 Mazda 6 Touring JL Fix 86 - OEM signal correction B2 prototype DSP 6to8 B2 Ref63 - 3 way active set 2 B2 Class H quattro's 1 B2 Zero.5R @.5 2 B2 HNv3 12 d2 B2 SLIP40 - Lithium in the trunk Northstar Group 35 under the hood 100ft 2/0 welding cable 30ft 4ga welding cable 20ft 8ga welding cable All stinger OFC speaker wire Soundrive custom RCA's Tons of attention to detail.... Can it be perfect?
bighossf150 Posted September 9, 2012 Author Report Posted September 9, 2012 Do it with the truck running I highly doubt having the truck on or off would make even a 2db difference with insane voltage drop, there's something else going on, can you be more specific with the system? Give us some details. 2 psi built hdc3 18's in a 11^3 wall tuned to 32hz with 195 sq in of port on an opti6k, all knu wiring and a pioneer 3100dvd hu. The hu clips at 38 so the gains on the amp were set with the hu at vol 37. Before the gain was around 1/2 and now it is around 1/4 but that is where the dd1 is picking up distortion. It sounds cleaner but is no where near as loud to the ear or the meter. Used to have a loud truck 2009 Corvette Z06, H/C/I, 150 shot, g force tune, 730rwhp/690rwtq 2013 F-150 limited, MPT Tune, leveled on 35"s
bighossf150 Posted September 9, 2012 Author Report Posted September 9, 2012 Why did you tune -5 db which is the SQ setting and working on getting higher numbers. all I listen to is decaf pretty much and thats what track he recommends for his music Used to have a loud truck 2009 Corvette Z06, H/C/I, 150 shot, g force tune, 730rwhp/690rwtq 2013 F-150 limited, MPT Tune, leveled on 35"s
TRTC360 Posted September 9, 2012 Report Posted September 9, 2012 Sounds like you did something wrong with the wall, subs wired higher, or completely wrong, even if you rebuilt the wall worse then before I don't see a 5db difference. '93 Firebird Formula V8 H/U- Kenwood eXcelon KDC-X395 Mids/Highs Amp- Hifonics ZXI80.4 Wiring-KNU RCA's, Speaker Wire, And Two Runs Of Trystar 1/0 G34 Red Top and a 180amp Ford Alternator www.youtube.com/TRTC360
bighossf150 Posted September 9, 2012 Author Report Posted September 9, 2012 It did the 151 with wall thats in the truck now, the only difference was setting the gain with the dd1 and it lost 5 db Used to have a loud truck 2009 Corvette Z06, H/C/I, 150 shot, g force tune, 730rwhp/690rwtq 2013 F-150 limited, MPT Tune, leveled on 35"s
dyablo409 Posted September 9, 2012 Report Posted September 9, 2012 Check your rca I had one side go out on me and it made it quieter. Just make sure you have signal on both left and right.
