Yep tried telling the landlord(s) to come check out the problem but they said it should be ok for a week or two when their plumber can come out since mine was probably going to be to expensive when he is a good friend. Guess that's why you don't rent from family
Peel it off and feel if it's still sticky. if it is, I'd think you should be good to go. Aluminum won't corrode heavily unless exposed to salt water and butyl is unaffected.
Definitely let it dry out first. If the paper backing is still firmly stuck to the butyl rubber, that's a good sign. once it's dry, peel back a corner of the paper and test the stickiness of the butyl. if it's still sticks, it'll work fine. I know Damplifier is very water resistant, but this will probably be the ultimate test haha.
Edited by Second Skin
