Guest Posted September 10, 2012 Report Posted September 10, 2012 subsonic cuts off frequencies lower than where its set. lpf cuts off frequencies higher than where its set. if there is nothing under 30, and nothing over 35, then only 31, 32, 33, and 34hz are playing with no attenuation.
Kyblack76 Posted September 10, 2012 Report Posted September 10, 2012 Badda bing SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
AMERICAN BASSHEAD Posted September 10, 2012 Author Report Posted September 10, 2012 name='Kranny' timestamp='1347301607' post='2162190']subsonic cuts off frequencies lower than where its set. lpf cuts off frequencies higher than where its set. if there is nothing under 30, and nothing over 35, then only 31, 32, 33, and 34hz are playing with no attenuation. [/b] SWEET thanx for the class, any sugjestions based on box tuning? i was thinking SSF @ 30 and LPF @ 50
n8ball2013 Posted September 10, 2012 Report Posted September 10, 2012 depends on your mid range. most cross over aroudn 80 hz. unless they've got dedicated mid bass drivers. THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
CJSmith Posted September 10, 2012 Report Posted September 10, 2012 have you pulled the woofers out to make sure you dont havea ny wires touching the basket. Ive had that happen too. You also could have an alt going bad as well. ive seen taht happen too. Not to thread jack, but did you say a bad alt can put an amp into protect? Cause i was running my stock alt on my system and my amp never shut off (even though i only turned my gain up until i dropped to 13v) but 2 weeks ago, I bought a used Mechman 300 alt from a guy and now every time I turn my head unit up, my amp goes in to protect. Sometimes at around 13.4v and some songs I can play down into 12.9v. Is there a possibility my alt is bad? Thanks N8. *Rebuid in progress*
ChevyBoy95 Posted September 10, 2012 Report Posted September 10, 2012 name='Kranny' timestamp='1347301607' post='2162190']subsonic cuts off frequencies lower than where its set. lpf cuts off frequencies higher than where its set. if there is nothing under 30, and nothing over 35, then only 31, 32, 33, and 34hz are playing with no attenuation.[/b] SWEET thanx for the class, any sugjestions based on box tuning? i was thinking SSF @ 30 and LPF @ 50 if you are tuned to 35, put the SSF at 28-30hz, and put the LPF at about 70-90hz depending on what your midbass is xovered at. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
Guest Posted September 10, 2012 Report Posted September 10, 2012 subsonic is supposed to be set a few hertz below what your box is tuned at. the general rule of lpf is around 80-100hz.
Kyblack76 Posted September 10, 2012 Report Posted September 10, 2012 At the OP - its a great fuggin forum isn't it???.... Good, accurate,.. info coming outta your ear hole...... Huh? ...Dig it.... Do some tweaking and report back ... SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
AMERICAN BASSHEAD Posted September 10, 2012 Author Report Posted September 10, 2012 FOUND IT!!!!!!! Good call on the speaker wire N8, i finely got a chance to pull the subs (shits been crazy at the shop today) one of the terminals twisted and the banana clips where touching eachother, do i have anything to worry about? O i almost forgot GOD I LOVE THIS FUCKIN FORUM
Kyblack76 Posted September 10, 2012 Report Posted September 10, 2012 and again..... badda bing.... cool beans man....... go turn it up... Oh, and wheres a vid of your get up?... lets see.... SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
