Different size oil filter? - HELP
I just got back from the auto store getting ready to change the oil. The filter they gave me is smaller, but the threads and the position of the gasket of the same. The guy there assures me that it is fine - that it is the same on the inside, but just has a different casing. But I am still a bit iffy about putting such a smaller filter on.
Vehicle: 2003 Subaru Forester 2.5X
The one I took off: Motorcraft FL-1998
The one they gave me: Amsoil Ea 15k 12
Picture of the difference
Thats the filter I come up with too. You are cool!
Thats cool. Im way too old to be upset by shit like that. Your name is winston. Your own parents hated you even before you were born.
My penis is bigger than your penis
I'm far from loud and my roof/headliner flaps around like Adam's ass on a windy day. I think it depends more on the structure of the vehicle.
filters are the same inside as long as the screw and gasget match up your good each manufacturer for the most part change the size of there filter to be :differnt:
Smaller filter will usually give more oil pressure as well Which is always good
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
Yep, you're good. You should see how small the oil filter on my race car is. Probably about the same size as the smaller one pictured and cleans a 10 quart system at 8500+ rpm and 700 all-motor horsepower. You're good!
2006 Cadillac Escalade
2/3 drop on 28" wheels
Two RE SX 18" subs
RF T2500-1bdCP amp, 3531watts on birthsheet
Custom carbon fiber sub box
EVERYTHING else is stock, for now
149.4 @ 37hz, Termlab, dash, open window on two AQ3 18s all stock electrical, wired to .25 ohm on a RF T2500
148.8 @ 36hz, Termlab, dash, open window on one AQ3 18 all stock electrical, wired to .5 ohm on a RF T2500
147.8 @ 38hz, Termlab, legal, sealed on two RE SX 18s
146.4 @ 36hz, Termlab, legal, sealed on one RE SX 18
Link to my hack-built, stupid, carbon fiber wasting project.... http://www.stevemeadedesigns.com/board/topic/149946-carbon-fiber-box-update-1494db-37hz-on-tl/
http://gifsoup.com/NDM3MTc1MQ
Wrong. If the oil filter has any effect on your oil pressure, you have a bigger issue. That's like saying a larger ANL fuse will give your amp more wattage. A larger fuse might allow more to flow through it, but it won't increase anything downstream. Same concept with an oil filter.
Two RE SX 18" subs
AMSOIL = Fap fap fap. Run the amsoil from now on if you love your car.
Also, the filter will be fine.
Source: Parrot Asteroid Smart
Processor: Digital Designs X1
Amps: Soundstream Ref 4.920 + Soundstream Ref 4.400 + Soundstream DTR 3400
Front stage: Hertz 165xl + HL 70 + HT28
Rear fill: Hertz 165xl
Subs: 2 SA-12's
3-way active ftw
Thanks!
Every change, every 4.5k ;)
Thanks!
Depending on what type of oil you run (I'd recommend full synthetic AMSOIL, Royal Purple, Mobil, or Castrol) (in that order), you can go 10k no problem.
Subs: 2 SA-12's
3-way active ftw
