using -5 or -10db track?
true facts
you can buy a rap cd with bass louder than -10db (0 being loudest)
and you could download a horrible copy of a song from youtube converters and end up with -25dB bass...
so your gain setting is dependent on how loud the bass is in the majority of the music you play, using either bass knob, sub level, or volume to custom tailor each song because its a car audio system is not a ron popiel rotisserie kitchen where you set it and forget it
-5dB if you listen to bass cds(bass mechanik, dj billy)
-10db if you do not listen to loud rap/bass music
-15db wouldn't even use if you listen to rap/rock/dub/similar
  • Like (+1 Rep) 2
  • 2 months later...
What you mean by loud bass music? Lol
What to you mean what does he mean?
It's music, with bass that's loud AKA an amplitude of something like -5db
I just met in the middle and made a -7.5 dB tone on Audacity.
1996 GMC Sonoma
Four Fi BTL Neo 18's In 2:1 6th Order Bandpass
2 Ampere 5k's @ .5
TEAM FI
TEAM #LITHIUMCANTDEMO
On 10/20/2013 at 0:37 AM, KillaCam said:
Fucking with a Prius driver is like making fun of a disabled kid. Pussies.
Ill save you the headache..... -0db for both 1k and 40hz for the head unit..... And then go -5db for both 1k and 40hz.... Then you never have to ever worry. Full tilt... No prob! Full tilt 30 mins? No prob! Just make sure you have clean music. I'd check out decaf stuff. Hint google search ram designs. :). I play 80% of decaf and I'm set with all -5db and sounds great.... Sure on normal rap CD's it's not quite as loud cause they record on higher -db signals... Like I herd someone say the original "White Girl" by young Jerzy off his cd that was purchased in the store was either -9 or -7db.... Therefor gains set for a max of -5db would still be pretty close and you don't have to worry about smoking your subs as much....
And on that note.... Gives you more of an excuse to listen to more decaf !!
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
Jeezy..... Damn you auto correct on my iPad
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
  • 1 month later...
I dont know if this really matters or not but I cant get 1k thru my sub rca im assuming theres a setting or somthing so 1k can't ge thru. but reg front and rear 40hz and 1k are clean up to volume 59. So ive used only 40hz on sub rca. headunit deh-6000ub
Headunit in mustang deh-p7000bt (Max undistorted volume 59) Headunit in gti deh-6000ub (max undistored volume 59) Amp=saz-1000d (Gain set with dd-1) Subwoofer= psi platform 3 18" (dual 1ohm)
yeah because your woofers dont play that high.you're doing it right.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
  • Who's Online   0 Members, 0 Anonymous, 1802 Guests (See full list)
