XS Power
buy a bigger amp the liitle bit of added power of a 1200 watt amp at .5 ohms is not worth the current draw you will face
a bigger amp at 1 ohm will most likly pull less current and give ya more power
  • Like (+1 Rep) 5
id realistically predict about 200 watts extra out of that amp. it will be inaudible
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Untitled.jpg Edited by finkster
  • Like (+1 Rep) 8
Eclipse cd7000
you could spend the money to buy a second AQ amp to strap it and ACTUALLY SAVE $, rather than doing the electrical upgrades necessary to run something so small on .5 ohm. although upgraded electrical is always going to be good. an added point....your electrical that you have will probably be fine for two of those AQ's strapped at 2 ohms, if im wrong somebody else can chime in on that.
he would stinn need to upgrade eletrical if he buys a second 1200
2400 watts on stock is not gonna fly
