TylerParrish Posted September 27, 2012 Author Report Posted September 27, 2012 still kinda wondering what a PCM actually does though? What the f**k is an appropriate signature supposed to look like?2013 Kia Forte Koup Pioneer AVH-X4600BT iDMax 12 DD M1c @ 2 ohms Rockford Prime 200.2 Pioneer 6.75" Comp Set XS S3400, D2700 Project DB Battery Terminals Axxess ASWC Stinger HPM Everywhereeee 90 Sq. Ft. of Stinger Roadkill Stock Alt Stuff To Come Sundown X-12 New Amp New Comps 4 Channel Amp My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/ My Old Build: http://www.stevemead..._+2000 +mustang Avatar Courtesy of SnowDrifter
MrSkippyJ Posted September 27, 2012 Report Posted September 27, 2012 Basically, from what I can gather, is that the cars computer controls the alternators output. I think anyway. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
roscoe1129 Posted September 27, 2012 Report Posted September 27, 2012 pcm = power control module or management. and yeah the vehicles "computer" says when to kick up the voltage Some people need a sympathetic pat... on the head...with my hammer Scientia est Vox "In Nomine Patris et Filii et Spiritus Sancti" DONT BE AFRAID TO USE THE SEARCH BUTTON!!! SMD SUPER BUYER/SELLER
TylerParrish Posted September 27, 2012 Author Report Posted September 27, 2012 Basically, from what I can gather, is that the cars computer controls the alternators output. I think anyway. i just looked it up in a little less specific of a way, think it actually keeps a check on and regulates almost everything in the engine. Still don't see how it could change the alternator output though or what it does for or to the alt at all. What the f**k is an appropriate signature supposed to look like?2013 Kia Forte Koup Pioneer AVH-X4600BT iDMax 12 DD M1c @ 2 ohms Rockford Prime 200.2 Pioneer 6.75" Comp Set XS S3400, D2700 Project DB Battery Terminals Axxess ASWC Stinger HPM Everywhereeee 90 Sq. Ft. of Stinger Roadkill Stock Alt Stuff To Come Sundown X-12 New Amp New Comps 4 Channel Amp My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/ My Old Build: http://www.stevemead..._+2000 +mustang Avatar Courtesy of SnowDrifter
Lbox88 Posted September 27, 2012 Report Posted September 27, 2012 It controls your charge voltage I believe. It monitors the battery level an adjust accordingly, so if it thinks the battery is fully charged, it drops the output of the alternator from say 14.7V down to 12.5ish so that the battery doesn't overcharge. One way to overcome this with some vehicles is to either turn on the parking lamps, or in my case I have to turn the headlights on. My Equinox likes to charge at 14.6 volts hot, and once it feels the batts are full it slowly drops to 12.5 unless I turn the headlights on. If I do that it brings the charge voltage back up to 13.9-14V until the battery appears drained enough that the alternator is brought full on and charges at 14.6 again. Pain in the ass. Also, I see Ray is lurking, wonder if he has any input UBL | Build Log
TylerParrish Posted September 27, 2012 Author Report Posted September 27, 2012 pcm = power control module or management. and yeah the vehicles "computer" says when to kick up the voltage is it a bad thing for the alt to have a PCM controlled car? What the f**k is an appropriate signature supposed to look like?2013 Kia Forte Koup Pioneer AVH-X4600BT iDMax 12 DD M1c @ 2 ohms Rockford Prime 200.2 Pioneer 6.75" Comp Set XS S3400, D2700 Project DB Battery Terminals Axxess ASWC Stinger HPM Everywhereeee 90 Sq. Ft. of Stinger Roadkill Stock Alt Stuff To Come Sundown X-12 New Amp New Comps 4 Channel Amp My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/ My Old Build: http://www.stevemead..._+2000 +mustang Avatar Courtesy of SnowDrifter
TylerParrish Posted September 27, 2012 Author Report Posted September 27, 2012 It controls your charge voltage I believe. It monitors the battery level an adjust accordingly, so if it thinks the battery is fully charged, it drops the output of the alternator from say 14.7V down to 12.5ish so that the battery doesn't overcharge. One way to overcome this with some vehicles is to either turn on the parking lamps, or in my case I have to turn the headlights on. My Equinox likes to charge at 14.6 volts hot, and once it feels the batts are full it slowly drops to 12.5 unless I turn the headlights on. If I do that it brings the charge voltage back up to 13.9-14V until the battery appears drained enough that the alternator is brought full on and charges at 14.6 again. Pain in the ass. Also, I see Ray is lurking, wonder if he has any input Haven't got to drive with the volt meter hooked up yet, so not sure what my car does. What the f**k is an appropriate signature supposed to look like?2013 Kia Forte Koup Pioneer AVH-X4600BT iDMax 12 DD M1c @ 2 ohms Rockford Prime 200.2 Pioneer 6.75" Comp Set XS S3400, D2700 Project DB Battery Terminals Axxess ASWC Stinger HPM Everywhereeee 90 Sq. Ft. of Stinger Roadkill Stock Alt Stuff To Come Sundown X-12 New Amp New Comps 4 Channel Amp My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/ My Old Build: http://www.stevemead..._+2000 +mustang Avatar Courtesy of SnowDrifter
Aaron Todessa Posted September 27, 2012 Report Posted September 27, 2012 its just typical over engineering and a pain in the ass. if you equinox drops to 12.5 at anytime while driving you have a charging circuit issue, or alternator going bad or bad signal to or from the pcm/ipc dynamic, or bad pcm. plain and simple.
