Excessive Amperage Alt **Tested @ 239a this morning**
Seems weird that your dropping that low on only 2k.Have you tested both batteries? I battery can have a bad cell and still read the correct voltage.
Vehicle
2007 Chevrolet Avalanche(Co-Co)
DNX9980HD
6 Team Fi 15's(King Edition)
3 DC 9k's
8 Nendo PWX 8's
4 Custom Steg 4" Super Tweeters
1 DC Audio 175.4
1 DC Audio 90.4
Rockford 360.3
3 DC Power 370xp Alts(Externally regulated)
21 D1600's
2 D4800's
All SMD RCA's
AudioTechnix Deadner
Viper Alarm
My YouTube- http://www.youtube.c...NG?feature=mhee
Link to buildlog- http://www.stevemead...4-15s-2-dc-9ks/
Link to UBL- http://www.stevemeadedesigns.com/board/topic/165059-ublkings-avalanchecoco-new-build-starting8-king-edition-15-team-fis-in-a-wallyes-a-wall/
this.
compare front to rear voltage. recheck your crimps. You didn't over tighten then power stud? If you break that or crack it, you'll kill output and probably your alt. Once you go below 13 you're dipping into battery power. So if you stay in the high 11s low 12s for a few, it'll take a second to charge your ish back up. I think you need a smaller pulley.
200 as per spec..
Try a 250 or 300 just for S&G.
Hammerdown... 1%
Both batteries are basically brand new.. like less than 6mo old.. both resting In the 13s but I know as you said. That doesn't also mean their good. I'll do a few of those suggestions and get back to you all on that.
Measure voltage at bat instead of amp to see if drop is the same:
Try bigger fuses:
When I took it the alt to get load tested. The guy mentioned that I couldn't use a smaller pulley as its already the smallest I could use..
Setup:
2010 Hyundai Elantra
Excessive Amperage "H/O" Alt
Xs D3400/ Xs XP3000
DD M3b and 2 12" AQ HDC4s
Try bigger fuses:
will be tuned into your results
you mentioned earlier in the thread that your deck was tuned with DD1. Was the amp gain also tuned ?
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
  • Who's Online   0 Members, 0 Anonymous, 1065 Guests (See full list)
