Excessive Amperage Alt **Tested @ 239a this morning**
glad you went with excessive, that's where I'll be gettin mine from too, a 300 amp alt for $490 shipped, the 270 from Mechman was the same price for my car.
What the f**k is an appropriate signature supposed to look like?
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
Rockford Prime 200.2
Pioneer 6.75" Comp Set
XS S3400, D2700
Project DB Battery Terminals
Axxess ASWC
Stinger HPM Everywhereeee
90 Sq. Ft. of Stinger Roadkill
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/
My Old Build: http://www.stevemead..._+2000 +mustang
Avatar Courtesy of SnowDrifter
I'm not sure how you would load test a 300+ amp alt let alone a 400+ amp alt. Do you realize what kind of heat the load tester would have to dissipate to test that? try this, find a 5000 watt light bulb and see how close you can get to it, that alt is putting out 14.4v at 400+ amps, that is over 5000 watts of heat dude.
edit
typo
so tell me... how can he then rate it at 425a then. if he couldnt clamps that from the alt?
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
yea i have big 3 done already.. I forgot to talk about casing... i got a 200a alt. he said it does more but he just rates them at 200.. but i hope he doesnt use the Cs130 casing ive heard from numerous people that it sucks balls, i left him a VM like 30 min later saying id prefer the ad244 casing if for nothing else than it will fit more vehicles if i were to sell later..
Setup:
2010 Hyundai Elantra
Factory Unit via 4 chan NVX LOC
Excessive Amperage "H/O" Alt
Xs D3400/ Xs XP3000
Big 3. 2 Runs of +, 2 Runs of -
DD M3b and 2 12" AQ HDC4s
So I got my alt in the other day.
Its a direct replacement, as the way it fits, not much else will fit w/o some modding or w.e which im not willing to do.
Its a 200a unit which Nate at EA said tested out at 250a. He originally told me that itll do more than 200a but he just rates em at 200a to be safe..
Anyway his CS was pretty good, and it got to me fairly quickly. its going in tomarrow.
I put up a small vid of my current voltage situation.
http://www.facebook....27012795&type=2
embedding > me i tried and searched and nothing..
but as you can see the voltage goes >16 several times.. only happens when its cold. after it warms up I get a constant 15.0+ but not 16..
amp is in protect so i know the 16.0 is pretty right as far as the meter goes..
pix:
Setup:
Xs D3400/ Xs XP3000
Installed my alt today..
So I have some concerns or maybe Im just not understanding this right.
First the positives:
It took me about an hour or less to take the old unit out and swap in the new EA one. Bolted right up.
Old Alt out
New Alt In :P
D3400 Resting Voltage before install
xp3000 resting voltage before install
now hear me out---
Big 3 is already done in 1/0
bat to strut tower
alt mount to strut tower (engine ground)
alt to bat
The amp is rated 2k or so should pull around 200a
Now imo idk maybe ive got this wrong , but
the amp most likely isnt pulling 200a for one
the alt is suppossed to put out 200 but he benched it at 250..
with two big ole batts
I shouldnt be seeing drop into the 11s.. like wtf is going on. It only does a shade better than my old stock alt.
Theres a point in the video where voltage is up some around 12.5-13v but i had the revs at like 2500 rpm.. like oops
I guess i was hoping for almost no drop especially if the alt is doing more than 200 like 250 as he mentioned
Ill call him tomarrow, but im just making sure im not going crazy here..
I mean my voltage is steady at 14.5 while driving with normal leves of music like listening to talk radio etc and it doesnt bounce around or spike in the 16s and cause my amp to protect anymore. My lights used to pulse up and down and the revs would go up and down too.. a tiny bit and it doesnt do that anymore either. So its a solid alt, but i could have gotten all that from a brand stock alt.. the reason i spend the extra $$$$ is for the H/O part of that.. which it doesnt look like i have..
anyway heres the video i made its kinda grainy at parts, as i took it on my phone.. sorry about that
Any help etc is appreciated, thanks
Setup:
Xs D3400/ Xs XP3000
well your car does need 80ish amps to operate, and once the alt is hot it wont do the 200 more like 170ish. Therefore you basically only have 90amps left for the system and the battery reserve. Running that crescendo at half ohm is going to become less efficient, so instead of using 200amps of current it'll use more. but anyways check all your connections make sure they are tight and secure and clamp the alt.
edit: also check for belt slip
Good info here.....
Only thing I wanted to add is after all that you might want to consider another batt after seeing you're running at .5
97 Suburban
8 custom PSI Platform 3 18's
I understand that. But if you assume numbers are correct.. about the car using 80a then what do you think happens on the stock 105a alt.. that's hillarious if you think im bass racing etc on less than 20a of alt.. no way.
Setup:
Xs D3400/ Xs XP3000
I'm going up to AutoZone to test it. Ive read a few places that this isnt ideal but well see anyway..
Setup:
Xs D3400/ Xs XP3000
  • Who's Online   0 Members, 0 Anonymous, 2557 Guests (See full list)
