RF4LIFE Posted October 11, 2012 Author Report Posted October 11, 2012 Well will the back battery over power the front battery or should I get two of the same battery?
ALPINE408 Posted October 11, 2012 Report Posted October 11, 2012 HA! back batter over power the front?????????? batts do not produce power they store it and thats it so if you have a little storage with a big storage it = MORE STORAGE Have you ever had your woofers blown?
WastedTalent Posted October 11, 2012 Report Posted October 11, 2012 I always heard that the back should be same size or smaller... but, I've learned otherwise. It doesn't matter. In a sense, they combine and equal 1 battery. So you can have a small pos up front and a huge beast in the back. Or vice versa. Won't matter how it's done. Sheena = pedobear
Tarball Posted October 11, 2012 Report Posted October 11, 2012 I think maybe you are thinking about your electrical system the wrong way. The batteries don't run your system, the alt does. Ideally you want an alternator that can output as much (or more) as your total amp draw of all electrical components in your vehicle. Remember, often when you are "cutting cost" or "taking shortcuts" you are also "introducing risk". CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db
RF4LIFE Posted October 11, 2012 Author Report Posted October 11, 2012 Well if you have a AAA battery and a D battery that are both 1.5v the AAA will corrode due to the battery's trying to reach an equilibrium in Amps
WastedTalent Posted October 11, 2012 Report Posted October 11, 2012 That's why you get the same voltage batteries. You don't buy a 12 volt and 16 volt. Lol. You keep em the same. And yes, alts run the system (not just system but entire electrical system). If the electrical needs are too much for the alt? power comes from battery. Sheena = pedobear
Ninja_v1.0 Posted October 11, 2012 Report Posted October 11, 2012 Well if you have a AAA battery and a D battery that are both 1.5v the AAA will corrode due to the battery's trying to reach an equilibrium in Amps what da fuck dis knegrow just say When your at the top everyone is coming for you, friends, family, haters and even those who don't know you.. my advice.. KILL EM ALL
WastedTalent Posted October 11, 2012 Report Posted October 11, 2012 He meant that if you put two different voltage of batts together, wire them in series or whatnot, the lower voltage batt will die quickly because it's trying to reach other batt's voltage. Lol. Just get batteries of the same voltage. Sheena = pedobear
Ninja_v1.0 Posted October 11, 2012 Report Posted October 11, 2012 He meant that if you put two different voltage of batts together, wire them in series or whatnot, the lower voltage batt will die quickly because it's trying to reach other batt's voltage. Lol. Just get batteries of the same voltage. i know was just really trying to be a smart ass lol When your at the top everyone is coming for you, friends, family, haters and even those who don't know you.. my advice.. KILL EM ALL
