Let's talk flat frequency response.... hmmm that 40-50hz might be cancellation?
Yeah I was really hoping it would go away when I face them to front and sealed off, or see if sound deadener would changed anything.
My 150+ Trunk Build Log
Current Setup
2 DC XL15's
Crossfire XS-8K
AudioControl Epic-150
Mechman 250 amp alt
XS D3100 under hood
2 XS D3100 in Trunk
SecondSkin Sound Deadening - 120+ sq ft Damplifier Pro
2012 North American Street Stock Runner-up - 150.9 on 1800 clamped watts
2013 dB Drag Street Trunk World Champion - 153.9 on 3200 clamped Watts
2013 MECA Trunk 1 World Champion - 152.8 Headrest
2013 MECA Park & Pound 2 World Champion - 130.6
My youtube channel (click for Hairtricks)
Team dbAddicts
Team DC Audio dcsoundlab.com
really really nice i wish i could do that on my mazda 3 lol :) :)
2010 Mazda 3
*Rebuild Time*
Subs - (2) AA Mayhems 12's
Sub amp - (1) Populus Audio TPA 6500
Headunit - Pioneer App Radio 2
Batteries - XS Power (1) D3100 up front | 6 XP950 rear
Wire - Sky High 1/0 Gauge wires and RCA's and steve's VM1
Alternator - Singer 260 Externally Regulated
Front Stage: (2) PRV Audio 10W650A (4) PRV Audio 8MR500-PhP-4 (4) DS Bullet Tweets | (2) 6.5 Components (Rear doors)
Mids & high Amp : (2) Populus Audio 100.4
Processor: Rockford 3sixty.3
The Build Log : http://www.stevemeadedesigns.com/board/topic/175922-2010-mazda-3-2-aa-mayhems-12-pg14-new-video/page-11
Aren't W7's SQ subs, and i recommend facing them forward and sealing it off from the cabin better numbers that way, Also there plenty loud if done correctly i had 2 w6's in a custom ported box @ 31 hz on power acoustik BAMF 5500 watt amp and a audio control epicenter and it killed the lows and flexed everything even somehow pushed out one side of my back windshield. also did 144.2 on TL sealed.
Yeah they are SQ subs but basically my goal was to see how loud I could get them since I already had one and could get another one very cheap. Everyone always says JL's cant get loud but I kinda felt like they had it in them so I thought I'd give it a shot. I did face them forward, getting there, stay tuned.
They do get loud but i dnt think 150db loud i tried everything i could but never got over that 144 mayb the car but hey i tried it was fun though...I trying to put together a 150+ build now 1 soundstream xxx 18 & crescendo BC5500 that should be fun i just got to get the money together cause im in the Bahamas not much high end stuff setting in the stores everything has to be ordered but keep them vids coming
How are we tuning both amps? I'm sure you have one amp to each sub.... Look at the sub movements during the frequency duration to ensure both subs are moving at the same direction and same distance.... I've have similar issue with my AQ HDC3 10's in the past... end up being both subs have different motor size gap lol.
My Build Log- T E A M S U N D O W N A U D I O -
2013 DbDrag WF SS1-2 - 5th Place 154.6db
2013 MECA Mod3 CA State Final Champ 153.4db
Powered by: Sundown Audio
How are we tuning both amps? I'm sure you have one amp to each sub.... Look at the sub movements during the frequency duration to ensure both subs are moving at the same direction and same distance.... I've have similar issue with my AQ HDC3 10's in the pass... end up being both subs have different motor size gap lol.
Hmm thats interesting. It was doing it even with only one sub in the car. I even tried my buddys Orion 2500 on the two subs and it still did it so I'm pretty sure there were standing waves in the trunk when the subs were facing to the back.
Current Setup
2 DC XL15's
Crossfire XS-8K
Mechman 250 amp alt
XS D3100 under hood
2 XS D3100 in Trunk
Team dbAddicts
Could be the car but I still think it could be sub/box. I've tried two different boxes and few different amps with similar output so ended up taking those subs out. If it doesn't bother you then it's fine. But that shit drives me nuts because it's really loud on certain notes and then quiet suddenly.
I got a great hookup with some SecondSkin deadener through a friend of mine. I did the trunk lid first to see if it helped and it made a big difference. I gained a dB at the low 17hz note and greatly reduced the rattles.
Went to one show with the subs facing the rear, did a 144.8 @ 18hz NSPL Car Hardcore. Someone at the show managed to get a vid. The trunk lid was still shaking pretty bad during the lows even after 2 layers of Damplifier pro on lid. It caused a bolt to come loose inside the trunk lid and you can hear it rattling in the video lol
Event results... http://www.termpro.com/asp/officialevent.asp?EventID=12515&Method=1027
Current Setup
2 DC XL15's
Crossfire XS-8K
Mechman 250 amp alt
XS D3100 under hood
2 XS D3100 in Trunk
Team dbAddicts
Another vid, this thing's moving air like crazy!
Current Setup
2 DC XL15's
Crossfire XS-8K
Mechman 250 amp alt
XS D3100 under hood
2 XS D3100 in Trunk
Team dbAddicts
Got them sealed off pretty good. First test did 146.9 sealed on the dash at 51hz on about 1800 watts. Still on stock electrical
The pic above shows the two port plugs I made from wrapping a carboard tube with tape till it was a snug fit. The tube is also filled with foam underneath the tape. This drops the tuning from 45 to about 33hz for daily.
Current Setup
2 DC XL15's
Crossfire XS-8K
Mechman 250 amp alt
XS D3100 under hood
2 XS D3100 in Trunk
Team dbAddicts
  • Who's Online   1 Member, 0 Anonymous, 1438 Guests (See full list)
