While those were drying some more resin was applied to the box
Little cheat sheet I made up for each section of the box.
Port is coming together, these pieces are ready to be glued into one.
Am I crazy or does that spell JL
Or it could be an M
Now its starting to look like a port
Apply a liberal amount of glue lol
The pieces you see inside the cutout of the baffle will evetually be attached to the back of the port like a rear flare.
Rounded sub hole looks nice
My 150+ Trunk Build Log
Current Setup
2 DC XL15's
Crossfire XS-8K
AudioControl Epic-150
Mechman 250 amp alt
XS D3100 under hood
2 XS D3100 in Trunk
SecondSkin Sound Deadening - 120+ sq ft Damplifier Pro
2012 North American Street Stock Runner-up - 150.9 on 1800 clamped watts
2013 dB Drag Street Trunk World Champion - 153.9 on 3200 clamped Watts
2013 MECA Trunk 1 World Champion - 152.8 Headrest
2013 MECA Park & Pound 2 World Champion - 130.6
My youtube channel (click for Hairtricks)
Team dbAddicts
Team DC Audio dcsoundlab.com
I need a saw like that... Every sheet i cut on mine is off slight and requires sanding FTL... Lol
Nice update though! I'm loving the pics of the build! Keep'm coming.
My Build Log- T E A M S U N D O W N A U D I O -
2013 DbDrag WF SS1-2 - 5th Place 154.6db
2013 MECA Mod3 CA State Final Champ 153.4db
Powered by: Sundown Audio
holy shit you guys had a lot of details in that box. awesome to see the work put in in the process you can't always see at the end. youd guys build some nice stuff for sure jordan. keep it up man. you guys are on the right track for sure
1999 Ford ExplorerTeam Sundown Audio4th 2012 Db Drag WF Street Stock 150.8dbYoutube Channel!http://www.youtube.com/user/BoomyurblownOperation 156 No wall Build Log!http://www.stevemead...x/#entry2196123
Thanks! Yeah that saw rocks. We used to use a p.o.s saw that took 5 minutes to set the fence for everycut and when your started it up the blade would wobble lol. This new saw easily cut the box build time in half if not more. I have lots more good pics I'll post later today :)
holy shit you guys had a lot of details in that box. awesome to see the work put in in the process you can't always see at the end. youd guys build some nice stuff for sure jordan. keep it up man. you guys are on the right track for sure.
Thanks alot Taylor. Yeah we spent alot of time on little details of this box. Maybe even too much time but hey it looks good. I even have a video I wanna post later too of some resin action
Current Setup
2 DC XL15's
Crossfire XS-8K
Mechman 250 amp alt
XS D3100 under hood
2 XS D3100 in Trunk
Team dbAddicts
I decided to smooth out the creases of the port with bondo before I router it. This was my first time using bondo and it didn't turn out as good as I had planned but it will be sanded and eventually painted over.
Bondo ready to be sanded
The port is going to be interchangeable. The port will be bolted to the faceplate underneath it and can be removed and replace with a lower tuned port which will be attached the same way. This means the holes better be pretty darn straight and accurate so I took the faceplate to the nearest drill press.
The faceplate will have T-nuts on the backside so that the holes dont get stripped out from repeated changes using wood screws. The T-nuts will be counter-bored into the surface about 1/8" so that they are definitely below the surface after I pound them in and this will also create a place for the resin to gather. The resin will help keep them from pushing out the back.
Here I am boring the hole for the T-nut using the milling machine at my work. Gotta love job perks
Bolted down with a few sockethead cap screws to test the fit.
Time to resin the back of the faceplate. I put the capscrews in the threads with teflon tape around them so that the resin doesnt get all through the T-nut.
After first coat and some sanding
All done with the faceplate
Current Setup
2 DC XL15's
Crossfire XS-8K
Mechman 250 amp alt
XS D3100 under hood
2 XS D3100 in Trunk
Team dbAddicts
I love it!!! More pictures please :)
Edit- I just downloaded that "boom button app", any idea how loud those frequencies are? Like -3db, 0db, -20db? Lol
2007 M/T Honda Civic Coupe EX
(4) Sundown Audio X-8's
(2) Ampere Audio 3800.1's
(3) Stinger SPV-44 Batteries
(1) Mechman 240
3:1 Ratio 4th order sealed from the trunk
TEAM NWSPL
Best termlab scores to date in Honda trunk:
151.7db legal (official) IASCA trunk 3 class
Best termlab scores to date in my walled Subie:
152.9db legal (unofficial) IASCA advanced 2 class
155db outlaw
Thanks! No not exactly I just know they aren't as loud as the dB Jams Vol 14 CD which i think is 0 dB
Current Setup
2 DC XL15's
Crossfire XS-8K
Mechman 250 amp alt
XS D3100 under hood
2 XS D3100 in Trunk
Team dbAddicts
Pretty man looks sick great numbers
4 kicker ks 60
1"AMERICAN BASS DOMES
RE DTS 80X2
AMERICAN BASS xd2000
2 OBSIDIAN 15D2
ALL KNU WIRING & RCA
THE BIG THREE
1.5FARAD MASSIVE AUDIO CAP
2.0FARAD MASSIVE AUDIO CAP
98 JEEP CHEROKEE
avic930
optima red top
american bass sq2000
Lining up the woodgrain........worth at least a tenth of a db.
:runlaugh:
2012 North American Street Stock Runner-up - 150.9 on 1800 clamped watts (Teammate)
2013 dB Drag Street Trunk World Champion - 153.9 on 3200 clamped Watts (Teammate)
2013 MECA Trunk 1 World Champion - 152.8 Headrest (Teammate)
2013 MECA Park & Pound 2 World Champion - 130.6 (Teammate)
Checkout our build and videos !! : ) 150+ Trunk Build Log itsgordy1 youtube channel (click for Hairtricks)
Smith's Custom Seats
Martinsburg, PA
(Second Skin Dealer)
  • Who's Online   1 Member, 0 Anonymous, 792 Guests (See full list)
