man thats awesome! good job on saving your amps with that upgrade, no Big 3 pics? or not done yet?
You can sort of see the Big 3 in some of the pictures. In the pics of the alternator you can see the red alternator-battery cable. The brown 1/0 in that picture is the upgraded engine block ground (moved to mounting bolt of the alternator and ran directly to battery bus bar). The OEM one was left intact on the other side (hard to get to). The light silver 1/0 in the battery pictures is the battery-chassis upgrade.
2012 North American Street Stock Runner-up - 150.9 on 1800 clamped watts (Teammate)
2013 dB Drag Street Trunk World Champion - 153.9 on 3200 clamped Watts (Teammate)
2013 MECA Trunk 1 World Champion - 152.8 Headrest (Teammate)
2013 MECA Park & Pound 2 World Champion - 130.6 (Teammate)
Checkout our build and videos !! : ) 150+ Trunk Build Log itsgordy1 youtube channel (click for Hairtricks)
Smith's Custom Seats
Martinsburg, PA
(Second Skin Dealer)
Thats pretty damn impressive!
2002 X type Jaguar
Two 12 inch DAD KMH Series wired down to 1 ohm
4ft^3 tuned @ 35hz
One Skar Audio Sk 800.1
Thanks Jarred for answering the Big 3 Question. I really dont have any good pics of that its somewhat hard to see.
So we did a test with the fluke..
How much DC current do you think 2 JL1000/1's can pull on a full volume burp through 1 run of 1/0 OFC to the trunk??
I was a little shocked when I saw this number.....
My 150+ Trunk Build Log
Current Setup
2 DC XL15's
Crossfire XS-8K
AudioControl Epic-150
Mechman 250 amp alt
XS D3100 under hood
2 XS D3100 in Trunk
SecondSkin Sound Deadening - 120+ sq ft Damplifier Pro
My youtube channel (click for Hairtricks)
Team dbAddicts
Team DC Audio dcsoundlab.com
I always wanted to know if it would be better to have the 2 subs in one common chamber rather than 2 separate boxes. I didn't think I could get one big box in the car when I started this build so thats why I went with two separate boxes. Now I wanted to cut a large opening between them and bolt them together.
I didnt want to rip the boxes out and ruin my seal-off job and possibly jeopardize the test so I decided I would take the subs out and cut an opening with the jigsaw. I took the subs out and covered the one sub hole with a mdf circle, taped a blanket all along the top edge of the box to keep the dust inside the box and not in my car. I got the shop vac hose inside the box and made my best attempt at cutting an opening between the boxes.
Here's the end result after bolting together and cleanup
I wasn't too concerned with keeping it neat since I was 90% sure I wanted to build a new box anyway.
So anyway, I don't have a termlab picture of the numbers after I cut the opening, but I can say I didn't gain or lose any dB. It was still in the 148.3 range. But the box rise did go down by .4 ohm.
But the other nice thing about joining the 2 boxes together was that it was now easier for me to tune lower which meant I could hopefully get the 17hz note even louder.
So we started testing different ports and tunings and started seeing some pretty insane numbers below 20hz. After a few hours late one night we hit the number shown below at 17hz, meter was at the passenger headrest and driver window was open. This was done with only one 4" aero port, partially internal and partially external.
We were also able to hit 146.4 with the meter at the windshield, but not sealed up, driver window must be down.
Here's some vids
Termlab vid for any nonbelievers
My favorite vid of them all. This one also shows the meter at the windshield score
Current Setup
2 DC XL15's
Crossfire XS-8K
Mechman 250 amp alt
XS D3100 under hood
2 XS D3100 in Trunk
Team dbAddicts
I was using either the dB Jams Vol. 14 or the aux in from the iPhone using the "Boom Button" app. Its a quick and easy way to test any frequency.
Current Setup
2 DC XL15's
Crossfire XS-8K
Mechman 250 amp alt
XS D3100 under hood
2 XS D3100 in Trunk
Team dbAddicts
So at this point I had 2 12W7's in two seperate boxes which are now joined as one. With four 4" aeroports and I plug some depending on what tuning I wanted. But I really wanted it to be louder so I decided to build a new box and try some different things.
The new box will be made from 3/4" birch and the inside will be coated with resin. I'm going to get one box for both subs in the car one way or another. Worst case scenario is I have to unbolt the door to get it in, or build part of it inside the car.
Time to go get some lumber :)
I got 2 sheets of Birch and 1 sheet of 1/2" mdf for other stuff like amp racks, ports etc.
Got all the pieces cut
Look at the layers!
Our new table saw rocks! Porter Cable FTW
Gluing the double-baffle together
More pics to come soon.
Current Setup
2 DC XL15's
Crossfire XS-8K
Mechman 250 amp alt
XS D3100 under hood
2 XS D3100 in Trunk
Team dbAddicts
Ok everybody, here's where the build log starts gettin good :) Jarred and I spent ALOT of time on this box and I have alot of good pics to share.
Box is starting to take shape
We had some small 45 scraps left over after cutting the angled sides to length so we used them to strengthen a few joints of the box.
I love when a plan comes together. Straight cuts FTW!
Drilling and screwing the 45 pieces together was a little tricky. This is what we came up with to keep the screws perfectly straight.
The step drill won't bend on the 45 and gets the countersink hole started.
Making 2 roundovers for left and right corners of box.
After a few coats of resin.
Thats it for now. Much more to come!
Current Setup
2 DC XL15's
Crossfire XS-8K
Mechman 250 amp alt
XS D3100 under hood
2 XS D3100 in Trunk
Team dbAddicts
Time to make some sub holes. Love the new router and circle jig!
Lookin good so far. I have a nice port planned for that piece on the right.
1st coat
Test fit... I like it
The stretched octo shape for the port will give me around 100sq inches which is about twice the port area of the first setup.
Port pieces cut, stood them up to see how they look.
How precise can we cut with our table saw? How about exactly to my drawings specs!!
Checking the fit of all the pieces... looks good.
We had alot of pieces that needed glued together so we made this 135 degree angle jig to cradle them all.
First batch
Second batch
Current Setup
2 DC XL15's
Crossfire XS-8K
Mechman 250 amp alt
XS D3100 under hood
2 XS D3100 in Trunk
Team dbAddicts
  • Who's Online   0 Members, 0 Anonymous, 1027 Guests (See full list)
