2012 Veloster - 1 HDC415 on 1 AQ3500.1
What happened to the corner of the box? Nice design for sure. Not that I know a damn thing about enclosure.
80prs
Arc Audio Xdi 1200.6 (using active crossovers) Freaking awesome amplifier
Incriminator IA 10.1
Focal PS 130v 5.25 (doors)
4" Faital pro Neo (kick panels)
3" Faital pro Neo and focal tweets( dash)
DC Audio level 3 12"  custom box designed by joex built by me
AGM front, XS 750SE batteries rear
DC 180 alt
99 Toyota Tacoma extra cab
http://www.stevemeadedesigns.com/board/topic/179476-my-small-build-turned-into-the-ongoing-build/
We demand vids of the system regardless of what they are! We would prefer vids with both amps though
I'll see what I can do ;)
Did you get the other amp in yet? And how is the voltage holding up? I'm thinking about running two of the same amps also , how many batteries are you running with the singer 200 amp alt?
I won't be putting the second amp in until I get an extra battery or 2. At the moment all I have is a D3400 up front and a D3100 in the rear and the singer alt. The voltage acutally holds in the upper 13's even at full tilt.
It got damaged in shipping. Two of the corners did actually. It's not too big of a deal as I sanded it out anyways.
DD M4
Rockford Fosgate P500-4
SoundQubed HDC415 w carbon fiber cap
2 Rockford Fosagate T1675-S
XS Power D3400 Under Hood
XS Power D5100 in rear
Michael Singer 200A Alt
Build Log: http://www.stevemeadedesigns.com/board/topic/153901-2012-veloster-update-842013-wall-build-4-15s/
Ok now you are just teasing us, putting in a single amp and saying how it sounds.... Get that other amp in and put up videos of some flex! I am betting on better numbers than the wall! I am calling a 151.4
Haha, I may be teasing just a little. I won't be putting the other amp in at the moment though. I gotta get some more juice in the battery department since each amp will be at .5. This setup is definitely capable of a 151.4 if you ask me. It won't do hair tricks like the wall did, but I think it should burp a pretty decent number as long as I can keep the voltage up.
DD M4
I'm interested to see how this turns out. I'm.getting stuff together to do a build in my wifes veloster, either gonna be 1 15 or 1 12 on 1500w
Used to have a loud truck
Nice dude. I'd love to see another Veloster build!
I honestly think this will move more air than expected. Those are bulletproof subs on ridiculous power in a box designed for maximum efficiency - I'm guessing a 153-4.
I appreciate the optimism! Unfortunately I doubt It hits that. It seems pretty loud even with one amp but I always get that feeling like it should be louder. I guess the meter will tell the true story. I really really really need to get a couple more batts though. That will make a big difference and allow me to install the second amp.
DD M4
Yea the hatch closes just fine with the subs inverted AND it gives me more enclosure space which is much needed, but it puts the equipment above the window line which I can't do if I want to compete.
DD M4
