Subwoofer still not moving.
Amart88
How is your box configured? could be a loading issue making one sub look as if it is not moving worth a shit while the other is moving alot depending on port configuration.
Daily Driver 1999 Kia Sephia
Kenwood DNX-893s
Audison Bit One Processor
2 Dat 4.125's
Sundown Audio SCV-6k
Hertz hsk-165xl's Mids running active        Focal V30 Series Tweeters running active
Sundown Sa-8 v1's in the doors
2 Sundown Zv5 12's
Lots of Hushmat
Big 3+ and 3 + & 3- runs of Trystar 2/0
2 Dc Power Engineering 320 HP Alts
2017 Comp Vehicle
2006 Toyota 4 Runner
Kenwood Excelon DNX-893s        Audison Bit One HD DSP
4 Sundown Sa 6.5v2 Component Sets
Focal Access 6.5 2 ways
Sundown Audio Sax-50.4        Sundown Audio Sax-100.4
2 Dc Power 370xp
Northstar agm27f
Northstar agm65
2 Northstar asmagm 480's
2 Dual 1 Sundown Nightshade v3 12's
2 Sundown SCV-7500's
All SMD Fuse Holders
Shitload Of Sundown 1/0
120 sq ft Second Skin Damp Pro
No, Its Not A Burp Truck!!!!
2016 Season 3rd place in Xtreme 1 At Finals
2016 Season 6th Place In Kaos 1 At Finals ( Blew The Subs Up In First Round Eliminations)
2 Kansas State Records Set In 2016 In Xtreme 1 And Kaos 1 In Midwest SPL
David said:
audio is a lifestyle, not a hobby
newls1
I cant read a tape to save my life... 1/2's are ok, but other marks confuse me
kingsuv
only men who cant read a tape, take it in the ass
kingsuv
you sir, get a pink hard hat on jobsites
It's a wall, each side close to 4 cubes. slot port in the center tuned to 33hz.
EDIT: I don;t think it's the box as when I switched amps the opposite woofer stopped moving. Also I remember having the suspect amp hooked up by its self before and there was barely any bass. So the rca's might not be the problem. will check them tomorrow, after that I guess i'm down to trying a new fuse.
Unhook the sub from said amp, take your DMM and see what kind of AC voltage you get from the amp, The speaker outputs are supposed to be paralled inside, they MAY not be and only 1 set works on your amp,
How are your RCAs hooked up?
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
Main set of RCA's coming from HU go to first amp (Working) then a set of jumpers from first amp to second. So I set my DMM to AC voltage and play a tone? Trying each speaker output with sub disconnected? Positive probe to pos and neg to neg? I get confused with it sometimes...
UPDATE: Sorry to double post but I just went out and checked my RCA's, they were fine, I took my dmm on a 40 hz tone and checked my speaker outputs on each amp. (woofers connected) The working amp showed 3.33 volts solid and the suspect amp was showing 0.1-0.7 of a volt fluctuating back and forth. It also showed 0.3 and slowly went down to 00.00v once. So now I guess it's figuring out whats causing the amp to do this. Crescendo said they tested it all over and it was working 100% perfect. So the problem must be on my end.
The ground for each amp is on the same buss bar, one on the top and one on the bottom of the same bolt. So maybe its my power cable not letting enough amps through (bad fuse)? Can I take the fuse out of the other cable and try it in this one? Sometimes when I put the fuse back in it sparks, I just don;t want to fry anything.
when changing the fuse disconnect the battery that will stop the spark.
and if i read that right you hace both amps gounded at the same spot? if so try moving one of the amp grounds to a different spot. i had an issue like this with my t1500.1bdcp sent it in and rockford side it was fine when i got it back i hooked everything up and it wasnt working moved the ground and it worked fine. the amp wasnt in protect and was on it just wasnt a good enough ground i guess.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
How did you jump the RCA cables?
Main RCA's come from HU to first amp then 2 foot set of RCA's go from 1st amps output to second amps intput rca. Not the strapping one.
@ alaskanzx5, Ok, thats something i could try, I can;t really disconnect my batteries as there are 3 of them in paralell with a ton of grounds and seperate bus bars so its not worth the hassle. Will that spark hurt anything?
  • Who's Online   0 Members, 0 Anonymous, 2073 Guests (See full list)
