soundstream15 Posted October 22, 2012 Report Posted October 22, 2012 So I plan on getting a 01 ford focus zx3 and its a hatchback, should get it in the next week but where do you ground the amp in this car? I never had a hatchback so not sure how different they are compared to trunks
SnowDrifter Posted October 23, 2012 Report Posted October 23, 2012 I did mine to the strut bolts ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
alaskanzx5 Posted November 27, 2012 Report Posted November 27, 2012 i know this thread is getting old but i just wanted to make sure that you are full aware of the best way to ground anything in a car. http://www.stevemeadedesigns.com/board/topic/156474-seatseat-belt-bolt-for-ground/ http://www.stevemeadedesigns.com/board/topic/155754-charging-systems-101-video-on-page-3/ http://www.stevemeadedesigns.com/board/topic/151155-the-big-3-upgrade-whats-the-real-benefit/ and check here for more info as needed http://www.stevemeadedesigns.com/board/forum/239-ce-auto-electric-supply-providing-solutions-to-all-of-your-automotive-electrical-needs/ t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
Tim Lam Posted November 28, 2012 Report Posted November 28, 2012 ANYWHERE! well anywhere that is bare, solid metal. (sand the paint off first for better conductivity) as stated above, strut towers are a common place to ground.
Nightshade Posted November 28, 2012 Report Posted November 28, 2012 I grounded mine on a bolt in the rear of the hatch that holds the latch for the hatch. It is a solid ground and is always best to use a bolt instead of screwing into bare metal. 2013 VW Jetta GLI 2.0 Turbo 1 Sundown Audio SCV2000 1 Sundown Audio X15 V2 1 XS Power D3100 Audio Control LC6i Stock Deck 146.4 sealed on the dash at 37hz 2001 Focus ZX3: RETIRED Team Sundown Audio, Team XS Power, 2 time NSPL Car 3601-Up Champion, 2 time NSPL Car Hardcore ChampionHighest NSPL Scores to date:154.3db on the dash sealed at 46hz, 156.2db in the kick at 46hz155.2db unofficial on dash at 43hz
alaskanzx5 Posted November 28, 2012 Report Posted November 28, 2012 ANYWHERE! well anywhere that is bare, solid metal. (sand the paint off first for better conductivity) as stated above, strut towers are a common place to ground. I grounded mine on a bolt in the rear of the hatch that holds the latch for the hatch. It is a solid ground and is always best to use a bolt instead of screwing into bare metal. yes both of those places work for a ground but neither are a better ground then the frame. if your gonna do it and the info is there on what is best which is provided by who i would say is the most informed person on this forum about car electrical systems then why not listen to it? why do it the easy way and possible have a loss of output or sq when you could have done it right the first time and be done with it? the info is there for everyone to see and learn from so make the better choice and make sure your wiring is done right the first time. i didn't know then what i do now so now i have to spend more time redoing some of the wiring. the way i see it is those that are ignorant are those that don't know but willing to learn, those that are stupid are not willing to learn. do it as you want but remember the choice you make is what determines if your ignorant or stupid. t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
