TylerParrish Posted October 22, 2012 Report Posted October 22, 2012 You have an amp with 2 + and 2 - and you only have one side hooked up? What the f**k is an appropriate signature supposed to look like?2013 Kia Forte Koup Pioneer AVH-X4600BT iDMax 12 DD M1c @ 2 ohms Rockford Prime 200.2 Pioneer 6.75" Comp Set XS S3400, D2700 Project DB Battery Terminals Axxess ASWC Stinger HPM Everywhereeee 90 Sq. Ft. of Stinger Roadkill Stock Alt Stuff To Come Sundown X-12 New Amp New Comps 4 Channel Amp My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/ My Old Build: http://www.stevemead..._+2000 +mustang Avatar Courtesy of SnowDrifter
HatersGonnaHate Posted October 22, 2012 Report Posted October 22, 2012 It will only play one side. Unless it's a mono amp, then it doesn't matter because all 4 terminals are internally bridged. They just use 4 terminals for the ease of wiring multiple subs. My name is AdamThis is my Civic Build.7" Samsung Tab 2Kenwood KDC-X896Clarion EQS746Sundown X-15DC 3.5k @2ohmHatersGonnaHate's 02 Civic UBLELD Bypass for Honda Civic/Accord/FitDon's Jeep Grand Cherokee Rebuild N8ball2013 - i think you'd stick your dick in a blender if it told you it was 40 wtih two kids your age. lol srp365 - If posting were picking up bitches, I'd be going home single tonight looks like tony montana sneezed in your car.
HHR Ed Posted October 22, 2012 Report Posted October 22, 2012 depends on the amp. Normally, nothing happens. If it is a mono amp, extreme nothing will happen. Ed Lester ShowtimeSPL Host Showtime Electronics Video MarketingMy old Build Loghttp://www.stevemead...08/#entry511451http://www.youtube.com/showtimespl 5 time dB Drag Finalist Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music New Ride, 2008 HHR SS. Build under way. Loudest score ever = 171dB 2009 dB Drag Racing, North American Points Champion
ALPINE408 Posted October 22, 2012 Report Posted October 22, 2012 depends on the amp some of em are just a bog block of metal to distribute the power some like the crown amps iirc have 2 seperate power supplys so you need both hooked up but why would you not run all the power and ground you can? there is a resone that tool makers and other dual wire imputs are so popular Have you ever had your woofers blown?
ALPINE408 Posted October 22, 2012 Report Posted October 22, 2012 depends on the amp. Normally, nothing happens. If it is a mono amp, extreme nothing will happen. is he talking about speaker or power wire? Have you ever had your woofers blown?
HHR Ed Posted October 22, 2012 Report Posted October 22, 2012 Some older class A/B 2 channel amps can be damaged if one channel has no load. Basically the components were heating up because of excess rail voltage with no load attached. Ed Lester ShowtimeSPL Host Showtime Electronics Video MarketingMy old Build Loghttp://www.stevemead...08/#entry511451http://www.youtube.com/showtimespl 5 time dB Drag Finalist Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music New Ride, 2008 HHR SS. Build under way. Loudest score ever = 171dB 2009 dB Drag Racing, North American Points Champion
ChevyBoy95 Posted October 22, 2012 Report Posted October 22, 2012 if it is 2 channel, then it will work like a 1 channel amp since only 1 is hooked up, you only get left or right signal. If it is a 1 channel amp with 2 + and 2 - then nothing will change between using both or single. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
HHR Ed Posted October 22, 2012 Report Posted October 22, 2012 hmm, need clarification. Do you mean speaker wire or power wire? Ed Lester ShowtimeSPL Host Showtime Electronics Video MarketingMy old Build Loghttp://www.stevemead...08/#entry511451http://www.youtube.com/showtimespl 5 time dB Drag Finalist Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music New Ride, 2008 HHR SS. Build under way. Loudest score ever = 171dB 2009 dB Drag Racing, North American Points Champion
HatersGonnaHate Posted October 22, 2012 Report Posted October 22, 2012 depends on the amp. Normally, nothing happens. If it is a mono amp, extreme nothing will happen. is he talking about speaker or power wire? He might be referring to the power/ground of the Sundown 4500.... Which I believe has dual inputs My name is AdamThis is my Civic Build.7" Samsung Tab 2Kenwood KDC-X896Clarion EQS746Sundown X-15DC 3.5k @2ohmHatersGonnaHate's 02 Civic UBLELD Bypass for Honda Civic/Accord/FitDon's Jeep Grand Cherokee Rebuild N8ball2013 - i think you'd stick your dick in a blender if it told you it was 40 wtih two kids your age. lol srp365 - If posting were picking up bitches, I'd be going home single tonight looks like tony montana sneezed in your car.
ALPINE408 Posted October 22, 2012 Report Posted October 22, 2012 mmmm im talking about dual main power and ground imputs his sig says SAZ 450 iirc has dual imputs and is a mono block Have you ever had your woofers blown?
