Landon75 Posted October 25, 2012 Report Posted October 25, 2012 What would be the best way to patch this up before it gets any worse. I was thinkin of just sticking some jb weld on it but there is probably a better way to do it.
Kyblack76 Posted October 25, 2012 Report Posted October 25, 2012 crack an egg(s) in it.... if your in a jam.... SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
reg93f150 Posted October 25, 2012 Report Posted October 25, 2012 i was gonna say put a table spoon or so of pepper in they're.. but then again.. dont, because it will get in your internals in your engine and could possible cause worse problems.. best way to fix it, buy another radiator. it will be worth it. ALL CREDIT TO XX1 FOR DC BANNER down rpping vanderbilt. 30 miles from victoria. i own the 3rd loudest setup here out of 3. but i did put together all 3 setups strapping 2 amps together ? like bolting them next together? using bungy cables to hold them down? or wiring separate amps to each sub
bass_stalker Posted October 25, 2012 Report Posted October 25, 2012 i'd just replace it. they arent that expensive, a new rad for my jeep was about 110 bucks, and its something you can replace yourself JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
reg93f150 Posted October 25, 2012 Report Posted October 25, 2012 yeah honestly i just replaced mine, cost me 123 dollars for all the fittings and radiator. took about 20 minutes to install, including draining other radiator, getting all the lines and transmission lines off, putting mine in, adding coolant and good to go! its actually alot easier then it looks.. just make sure to not twist the bigger nut on the transmission lines, just twist the nut on the transmission line otherwise you will fuck it up bad.. ALL CREDIT TO XX1 FOR DC BANNER down rpping vanderbilt. 30 miles from victoria. i own the 3rd loudest setup here out of 3. but i did put together all 3 setups strapping 2 amps together ? like bolting them next together? using bungy cables to hold them down? or wiring separate amps to each sub
Landon75 Posted October 26, 2012 Author Report Posted October 26, 2012 Hm i just had this bitch repaired yesterday the starter went out. I would have replaced it but i was stranded and i didnt feel like messing something up inthe parking lot. yeah honestly i just replaced mine, cost me 123 dollars for all the fittings and radiator. took about 20 minutes to install, including draining other radiator, getting all the lines and transmission lines off, putting mine in, adding coolant and good to go! its actually alot easier then it looks.. just make sure to not twist the bigger nut on the transmission lines, just twist the nut on the transmission line otherwise you will fuck it up bad.. I actualy replaced the radiator on my old saturn a year ago it was 65 bucks. i broke the transmission cooler line because it was rusted the radiator and that cost me another 25. This car is a headache one thing after another.
onebadmonte Posted October 26, 2012 Report Posted October 26, 2012 Sell the car and buy a bus pass. Broken plastic tanks are non-repairable. J B Weld wont stick from one side on plastic. You'd have to use J B weld on both sides of the crack. At that point you'd best try a radiator shop and see how much they'll charge to replace the tank. If you're daring enough you can buy just the tank and replace it yourself. O_o Warhorse vs A Pair of SMDeez build Olds Cutlass Cierra IB build 2 Fi IB3 18s
79Bronco Posted October 26, 2012 Report Posted October 26, 2012 Stop buying plastic tanks radiators. Buy a brass radiator and never have to fix another radiator again Source: Parrot Asteroid Smart Processor: Digital Designs X1 Amps: Soundstream Ref 4.920 + Soundstream Ref 4.400 + Soundstream DTR 3400 Front stage: Hertz 165xl + HL 70 + HT28 Rear fill: Hertz 165xl Subs: 2 SA-12's 3-way active ftw
Colin - STAPUFT Posted October 26, 2012 Report Posted October 26, 2012 What onebadmonte said. JB weld won't do it. You can try some Blue Devil (http://www.gobluedevil.com/) but it will cost about half as much as the radiator would anyway.... Sounds like bass_stalker has been here with radiator problems too. Same deal with my van once and my wifey's old Neon. Just replace the radiator- pretty much your only choice. 12 - 12"s in the STAY PUFT 1989 Chevy Astro Build & Comment Log Un-Interrupted Build LogYouTube Channel Chevy Trailblazer 5.1 Dolby Digital DTS Install You have a beard of a mysterious sea captain. I would follow you to hell and back.
CHEVY4X4BLAZER Posted October 26, 2012 Report Posted October 26, 2012 Best bet is replacement. Or carry a few gallons of water to refill it when it gets too hot . Then again, refilling with only water can lead to rust and rust is bad...mmmkay.
