Possible Spark Knock? How to Fix
If I remember right this is a fairly new motor that is in his car. Not the original.
formerly known as Blue86f150
its a 4th order just because its tuned in the 40z doesnt mean it wont reach down and jiggle your balls at sub 30 hz frequencies.
Regardless if they were dipped platinum and were stuffed in Beyonce's twat.....way too fucking exspensive
this sux camel dicks
get your knock sensor checked, might have gone bad or could have a bad connection.
try running mid grade fuel, might help, might not.
check your spark plugs.
Hammerdown... 1%
Check the fuel pump and anything in between it and the engine. When I had pinging it went away when I swapped to a bigger fuel pump. Maybe you have a dirty filter or a leak somewhere.
90 Nissan 240sx
Avic z-140bh
Audison SR4
Audison Voce 6.5s
CDT es-20 tweeters
Sundown 1500v3
(2) DD 9510's
3 cube box 2 6" aeros
XS Power D2400 & Xp950
Skyhigh/Knukonceptz/Rockford Fosgate wiring
More Coming Soon.. Check my builds below.
97 Civic Hatch Build
86 Caprice Build
you can pick up a chick in a car... I think it'd be hard to roll up mackin on a broad sittin on a sundown. My opinion
Higher octane will not help. The cars made to run on 87, run 87.
So you're telling me that when I encountered pinging (hot summer day, hauling), ended up throwing in 92 octane, after i ran out of 87, it didn't do any good since the pinging went away?
2015 Honda Civic LX 4dr | 24k miles
Stock H/U and mids/highs
Power Acoustik GW3-12" D2 Sub
HiFonics BXX1200.1D @ 1ohm
Random 2.5^3' dual ported box
NVX LOC
Stinger wiring throughout
1977 Chevy SWB
Cammed 350
Dual exhaust
Cheap Wish stereo
Is it a click noise, or a 'knock on a door' noise.
The former would be a valve issue, the latter a rod bearing issue.
On that car, not worth fixing. New motor or new car time.
It sounds like someone is randomely dropping bb pellets in my engine, it doesn't sync up with the RPMs
sounds like detonation from carbon build or your timing is off id check timing belt couldve skipped a tooth
I'm leaning more towards carbon build up, if anything
There is no knock sensor on this car :(
And yes, this is a replacement engine. Was a 40k from a JDM shop that works on imports
My Channel on YouTube. Check it out for cinematic-style Car Audio videos.
https://www.youtube.com/channel/UCcSMhtT-rpopJbdybubDgnQ
New 2014 Scion TC 4th Wall Build
https://www.stevemeadedesigns.com/board/topic/217173-2014-tc-4th-order-build-3-fi-sp4-15s/
http://www.toyoland.com/engines/4A-F.html
Might try a cold-air intake.. or just run mid/premium
Hammerdown... 1%
Are you using the USDM ecu or JDM?
I'm finding knock sensors for that motor...
NVX LOC
1977 Chevy SWB
Cammed 350
Dual exhaust
Cheap Wish stereo
I'm not exactly sure about the ECU. I'd have to get under the console and look. I've google searched and found some for the engine too, but on the 6th gen corolla forum on toyotanation I've read that the early 4AFE's didn't have them, but the later AE111 7AFE had them. I didn't find anything in the repair manual on it either, but if I had an idea where it was I could definitely look!
had a similar problem with my explorer like the guy in the vid, ended up being my plug wires, under load or acceleration it creates more of a load on the plug wires causing them to short out to the nearest ground, check your plugs and the only real way to check you plug wires is with an ohm meter, usually they range from 4k ohms to 7k ohms per foot
97 exploder xlt2 18" obsidian audio daul 2 v2s1 sundown audio saz1500d at .5 ohm2 sets of alpine type r components1 MB quart onyx 125.4alpine cda-98871 mike singer 250 amp altxs d3400 in the backall kicker wiringBIG 3singer resonance killer sound deadner throughout
  • Who's Online   1 Member, 1 Anonymous, 943 Guests (See full list)
