kurupt305 Posted November 1, 2012 Report Posted November 1, 2012 whats up so recently i swappped out my kicker 450 amp for a REFURBISHED soundstream rubicon 800.1 now whats happening is when i first turn on my wifes scion tc the sub pops i read about that and heard its no biggiie now when the cars rpm goes to roughly 1500 i hear noise like if someones messing with the rcas that noise comes and goes now what i noticed is my amp which has in internal fan seems to be projecting the fan noise or buzzing noise into the sub thus when i disconnect the sub from amp the sub noise goes away i was reading maybe i have a bad fan i tested my ground and its getting 12.7 with the car off so im guessing the ground is ok im really thinking this amp i got might have problems internally the bass works the sub hits and all any suggestions what might be happening? oh and another note with the rcas disconnected from the amp the buzzing noise still comes from the amp going to the sub
SnowDrifter Posted November 1, 2012 Report Posted November 1, 2012 Did you run your RCAs next to thr power wire? ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
kurupt305 Posted November 1, 2012 Author Report Posted November 1, 2012 with my old amp yes and i never had a problem but once i put this amp in my switched the rcas to the driver side of her scion and power and remote are on the passenger side i also just changed my rcas yest to some kicker ones
SnowDrifter Posted November 1, 2012 Report Posted November 1, 2012 Try grounding your RCAs at the head unit, as well as grounding the head unit itself ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
sbg Posted November 1, 2012 Report Posted November 1, 2012 Try grounding your RCAs at the head unit, as well as grounding the head unit itself learn something new everyday! 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
IBleedMusick Posted November 1, 2012 Report Posted November 1, 2012 We need to meet up tomorrow and take a look at it so I can better diagnose it but I knew something was wrong with the amp when you first told me how it arrived. I knew it would give you problems. We can try the RCA grounding but I doubt that's the issue considering this is a stock HU and this wasn't happening with the Kicker amp. I want to listen and try a few things and rule out all scenario's before you send it back. I never had this issue with any of my SS amps so I am thinking bad amp but I could be wrong it could be a simple fix...we shall see. 2013 Dodge Charger Build Log 1996 Ford Explorer XLT 5.0Build Log 2005 Honda Civic LX Coupe Build Log SMD SUPER SELLER!!!!My Selling Feedback
alaskanzx5 Posted November 1, 2012 Report Posted November 1, 2012 if its a pioneer do the rca trick i did with mine and it with my old one and it worked great after that. its the pico fuse pioneer uses. t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
kurupt305 Posted November 1, 2012 Author Report Posted November 1, 2012 Shit I rather just return it you guys are forgetting that with no rca connected to the amp and the amp on you hear a signal noise coming from the sub so something from the amp is projecting that noise to my sub
kurupt305 Posted November 1, 2012 Author Report Posted November 1, 2012 It is a pioneer and the amp still gets that static sound when the cars idle changes even with the rcas disconnected so has to something with the amp
