Good enough to you people?
TylerParrish
My radius is 2.25 inches on that kerf.
What the f**k is an appropriate signature supposed to look like?
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
Rockford Prime 200.2
Pioneer 6.75" Comp Set
XS S3400, D2700
Project DB Battery Terminals
Axxess ASWC
Stinger HPM Everywhereeee
90 Sq. Ft. of Stinger Roadkill
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/
My Old Build: http://www.stevemead..._+2000 +mustang
Avatar Courtesy of SnowDrifter
i like all the specs. especially with the 10s i like to stick closer to 36 hz tuning to protect them. i feel with a little larger subs you can get away with tuning higher since the suspensions are more forgiving. personally I wouldnt make this so complicated. did you calculate all the kerfs and what not? thats a pretty big part of your port. dont want your specs to be too far off after you build., and the v in the back of port is un neccessary.
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
Very similar to my box I built for two hdc3 10's... Except mine is a tad smaller. Spec looks good, I would give it a go!
My Build Log- T E A M S U N D O W N A U D I O -
2013 DbDrag WF SS1-2 - 5th Place 154.6db
2013 MECA Mod3 CA State Final Champ 153.4db
Powered by: Sundown Audio
I made the radius of the kerf what the radius of the port was, if that's not how to do it, that I'm gonna have to re-calculate some things real quick. I'll also definitely be taking that V out.
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
XS S3400, D2700
Axxess ASWC
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
Cool, I actually almost bought 2 hdc3 10's, but I didn't :/ Oh well, still happy with my purchase.
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
XS S3400, D2700
Axxess ASWC
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
looks wicked! Interested to see how it turns out!
Only thing I can really comment on as far as tuning goes is that I love my enclosure that's tuned to 36hz. Granted it is a DC Audio Level 5 M1 15" in a completely different car, but regardless, it's a good compromise in my case. It destroys the lows but still has enough in her to get pretty wild on the higher frequencies, although it's not as impressive over 50hz being that I have the LPF set at 60hz. With it off it's better, but I start to have voltage issues when I'm running it full tilt (amp pulls a lot more current up top, I'm thinking the impedance rise drops) so I just cross it at 60hz.
I have 8 8" woofers in a sealed box behind my front seat that have the high pass set to 60hz so I still get a decent amount of punch higher up.
I drew a top view of your box based on your Torres screenshot.
I assumed the 24" depth did not include your 3rd baffle reccess layer.
Sorry for the low res. AutoCad sucks for getting a JPG down to 800x600.
I can email you a lot higher res JPG or PDF...
'09 Sierra Ext Cab - under construction
(1) RF T2500-1 -running- (4) RF T1 12's
(1) RF T1000-4 -running- (2) RF T1652-S
Stock alt / battery -plus- (1) DC Power 230a & (2) Kinetik 1800
Buncha OFC Knu
Buncha Second Skin
Kenwood DDX814 - Alpine Imprint - RF 360.3
If you make the kerf the size of the radius, it should be 2.25, not 1/2 that.
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
XS S3400, D2700
Axxess ASWC
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
Yeah my fault, the dimension got cut off. (see the leader that goes nowhere?) The radius of the port/kerf is 2 1/4".
...But, that is not all effective port. Most of the time people say the effective length of the port is reduced by half the radius.
That's why I show the start of the port 1 1/8" behind the face of the baffle.
Buncha OFC Knu
Buncha Second Skin
wait what? you do know subs move less with higher tunning????? why would the suspension have to be more forgiving if there not abuse as much at a higher tunning???
i would tune to 38-39 i also hated my dd9500g's 10's anything lower than that the output would just drop off tunned lower then 38hz
  • Who's Online   0 Members, 0 Anonymous, 1098 Guests (See full list)
