Kris4b11 Posted November 30, 2012 Report Posted November 30, 2012 I recently ordered a bc3500 to run my dd9512i dual 2 and realized i never had a amp that had terminals like this ( -- ++ ) just use to ( +- +- ) or even only one set ( + - ) so i was wondering how do i wire down to one ohm ? maybe im putting too much thought into it i dont know lol. thanks in advance guys Factory double din navi unit with 30gb internal Crescendo bc3500 DD 9512i
HatersGonnaHate Posted November 30, 2012 Report Posted November 30, 2012 http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=1&I=22#results Just like the first pic in the link above. You only need to use one set of terminals, so one + and one -. They make them with 4 terminals for the ease of wiring multiple subs. My name is AdamThis is my Civic Build.7" Samsung Tab 2Kenwood KDC-X896Clarion EQS746Sundown X-15DC 3.5k @2ohmHatersGonnaHate's 02 Civic UBLELD Bypass for Honda Civic/Accord/FitDon's Jeep Grand Cherokee Rebuild N8ball2013 - i think you'd stick your dick in a blender if it told you it was 40 wtih two kids your age. lol srp365 - If posting were picking up bitches, I'd be going home single tonight looks like tony montana sneezed in your car.
Kris4b11 Posted November 30, 2012 Author Report Posted November 30, 2012 ook thanks i figured i just had to use one set , that 4 terminal setup threw me off lol ... so im assuming it would be like this (-) - (+) +? the terminals in the () are the ones used in this situation Factory double din navi unit with 30gb internal Crescendo bc3500 DD 9512i
Watch the bass Posted November 30, 2012 Report Posted November 30, 2012 Normaly there are internal bridged so it have nothing to say. "in the abundance of water, the fool is thirsty" Bob Marley
HatersGonnaHate Posted November 30, 2012 Report Posted November 30, 2012 ook thanks i figured i just had to use one set , that 4 terminal setup threw me off lol ... so im assuming it would be like this (-) - (+) +? the terminals in the () are the ones used in this situation Exactly right, at least that's how I do it anyway. As long as a + and - are used, it'll be fine. But when I do single sub setups on 4 terminal amp, I wire it up just like you have in the ().... It's an OCD thing My name is AdamThis is my Civic Build.7" Samsung Tab 2Kenwood KDC-X896Clarion EQS746Sundown X-15DC 3.5k @2ohmHatersGonnaHate's 02 Civic UBLELD Bypass for Honda Civic/Accord/FitDon's Jeep Grand Cherokee Rebuild N8ball2013 - i think you'd stick your dick in a blender if it told you it was 40 wtih two kids your age. lol srp365 - If posting were picking up bitches, I'd be going home single tonight looks like tony montana sneezed in your car.
wmrcs Posted November 30, 2012 Report Posted November 30, 2012 ook thanks i figured i just had to use one set , that 4 terminal setup threw me off lol ... so im assuming it would be like this (-) - (+) +? the terminals in the () are the ones used in this situation Exactly right, at least that's how I do it anyway. As long as a + and - are used, it'll be fine. But when I do single sub setups on 4 terminal amp, I wire it up just like you have in the ().... It's an OCD thing x2 lolol E34 540iT/6
DubNDodge Posted November 30, 2012 Report Posted November 30, 2012 Honestly was wondering the same thing. The mono amps with 4 terminals really threw me off too. So 4ohm DVC, each sub wired in parallel then each pos/neg wire connected to the pos/neg terminals on the amp will result in a 1 ohm load? '01 Dodge Stratass Sealed Trunk Build Log 2008 Honda Fit Sport Build Log On 10/3/2013 at 10:00 AM, ROLEXrifleman said: Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
Kris4b11 Posted November 30, 2012 Author Report Posted November 30, 2012 lol yea man so you completely understand where im coming from with these silly questions Factory double din navi unit with 30gb internal Crescendo bc3500 DD 9512i
HatersGonnaHate Posted November 30, 2012 Report Posted November 30, 2012 Honestly was wondering the same thing. The mono amps with 4 terminals really threw me off too. So 4ohm DVC, each sub wired in parallel then each pos/neg wire connected to the pos/neg terminals on the amp will result in a 1 ohm load? Exactly http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=2&I=42#results My name is AdamThis is my Civic Build.7" Samsung Tab 2Kenwood KDC-X896Clarion EQS746Sundown X-15DC 3.5k @2ohmHatersGonnaHate's 02 Civic UBLELD Bypass for Honda Civic/Accord/FitDon's Jeep Grand Cherokee Rebuild N8ball2013 - i think you'd stick your dick in a blender if it told you it was 40 wtih two kids your age. lol srp365 - If posting were picking up bitches, I'd be going home single tonight looks like tony montana sneezed in your car.
DubNDodge Posted November 30, 2012 Report Posted November 30, 2012 Just made my life easier. Was going to try and figure out how to connect 8 ga wires lol.. Wooo! '01 Dodge Stratass Sealed Trunk Build Log 2008 Honda Fit Sport Build Log On 10/3/2013 at 10:00 AM, ROLEXrifleman said: Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
